1989 Corvet Horn not working
My horn stoped working on my 1989 Corvett Convertable. I have checked the horn at the stearing weel and it is making contact, I have replaced the horn relay and it still does't work. There is no power to either location. I have a wiring digram and it showes a curtic breaker someware. Since I have no power I think this might be the problem but I don't know what it looks like or where it is located. Any help would be great since I can't get a sticker till I get the horn fixed.
Did you check the fuse? The contacts in the steering wheel complete the ground side of the circuit, so there would not be power there. If you can identify the wire going to the steering wheel from the relay, try grounding it with a jumper and see if the horns work. You can also test the horns themselves by jumping 12 volts to the proper terminal on them. Could be that they went bad one at a time, and you only noticed when the second one failed.
I did check the wires for power at the relay and there was none. I have a wiring diagram and it showes the power constant to the horn with no fuse. But it does have a circut breaker somewere. That's what I thing I need to find.
I believe that there are 2 fuses for the horn. One is an actual horn fuse and the other is the fuse for the alarm. If either is missing or blown, no power. Fuse panel is on the passenger side dash next to door.
I just replace mine with a "Bad Boy" from harbor freight. $30. Sounds like a Vette should.
I had the same problem , it was the alarm fuse in my 86 , it is behind the info panel , requires you to remove the centre dash panel to get to the fuse - I just replaced the 10 amp fues with a 15 amp one as the 10 amp one kept blowing (I have aftermarket horns installed by a previous owner) and it's good to go - silly place for that fuse as its a bit of a bear to get to it....
Did the bad boy horn come with wiring to install complete horn system, i.e. not just a horn replacement for the factory two horn units?
Originally Posted by Mr. CJ
(Post 1575265971)
There is no circuit breaker in the horn circuit, a fusible link that provides power to a bunch of fuses, and the "Theft Fuse" in auxiliary fuse block, behind center info panel.
If only the horn is not working, you can rule out the fusible link. Horn electrical >> http://members.shaw.ca/dankai/Horn%20Electrical.pdf http://members.shaw.ca/agent86/Behin...fo%20Panel.gif |
