New 482 Blown Injected BBC for sale
New, never fired big block Chevy engine. 482 stroker engine.
GM block, torque plate honed, align-bored, Milodon billet steel splayed four bolt main caps, block notched for stroker crank, decked, new freeze plugs, cam bearings, and galley plugs. Callies .250 steel crank, internally balanced Eagle H-beam rods Arias 9:1 full floater, forged blower pistons Arias Hell Fire file fit rings Clevitte 77 race bearings Comp Cams solid roller cam and lifters Comp Cams adjustable roller timing set 7/16" push rods Crane Gold roller rockers Crane stud girdles Merlin "Bill Jenkins" series iron heads 320 intake runners "D" port exhaust runners Stainless steel valves Triple valve springs good for .700" lift ARP studs top and bottom Mallory Unilite distributor Weiand polished 6-71 blower Weiand polished blower manifold Enderlie Injection with bird catcher I have everything to complete this engine except for rocker studs and guide plates, Oil pan, oil pump and pick up. I have $14K invested in the engine. This is a NEW engine, never fired. Serious inquiries only! The long block is built, the induction system is mocked up in the pictures. I'M ASKING $9,000 FOR EVERYTHING I HAVE. PHONE NUMBER IS (417) 634-0262 I'll trade for a second generation Dodge Charger, or a C-3 or C-4 of equal or lesser value http://i129.photobucket.com/albums/p...ke68/002-2.jpg |
I added a few more pieces. The valve covers either need breathers welded back on them where those scars are, or I have another set of welded aluminum valve covers that go with the engine that are new.
Bump
This is SOLD!
