When to change shocks??
I have a '98 coupe with 80K, and know the shocks are going to need replacing at some point. They "feel' OK now but was wondering at what mileage should I look at replacement.
I know every car will be different but I don't want to wait until they are shot and I don't want to replace unneccesarly.. At what mileage did those of you that have replaced shocks do so??? Thanks... |
Your either due or past due. Shocks wear out very slowly and you seldom feel the reduced handling unless you ride in a car with new ones or install new ones. What suspension option do you have??
One of the best shock up grades is the C6 ZO6 shocks. Yep,,, they are an OEM fit and will significantly improve the handling capability of the C5. Have you ever had the feeling that your C5 was going to skip of the highway in a high speed entrance ramp curve??:eek: My ZO6 even did it. Up-grading to the C6 ZO6 shocks eliminated that! Gene Culley has them for $250 ish for all four. www.gmpartshouse.com BC |
Originally Posted by Bill Curlee
(Post 1575086325)
C6 Z-06 shocks ae a direct bolt in replacement for all years/models of the C5 (except those with selective or magnetic ride control options) :thumbs:
Originally Posted by rws.1
(Post 1575086643)
BC |
I bought my 98 with 70k at 72k I replaced the shocks with C6Z06 shocks from Gene.
It was like a new car again. At 75k I got rid of the run flats Its even better now |
(Post 1575086777)
They also fit and work well on C5's with selective or magnetic ride control options,,,,,,,, BUT,,,, you have to deprogram the F55 and F45 from the BCM using the TECH 2 or use resistors inplace of the shocks for the F-45. Other wise the BCM and RTD module will throw DTCs and limit you to 80 MPH.
BC |
Originally Posted by Chicago1
(Post 1575089543)
How much does that cost using a tech 2?
(Post 1575086325)
BC Thanks... |
Originally Posted by TN Vette
(Post 1575089887)
Or how much can you get a decent shape Tech 2 used?
I got mine used for $1000 The dealer will charge you one hour labor.. You will get a less charge from a Service Garage that has one. BC |
(Post 1575091130)
New Tech 2 is about $4000.:eek:
(Post 1575091130)
(Post 1575086325)
One of the best shock up grades is the C6 ZO6 shocks. Yep,,, they are an OEM fit and will significantly improve the handling capability of the C5. Have you ever had the feeling that your C5 was going to skip of the highway in a high speed entrance ramp curve??:eek: My ZO6 even did it. Up-grading to the C6 ZO6 shocks eliminated that! Gene Culley has them for $250 ish for all four. www.gmpartshouse.com BC i have toggled the selective ride to all options but it doesn't feels any better (rigid),, they all feel almost the same,, am i having a problem with my selective ride (no DIC)?? is it easy to place those resistors if installed Z06 shocks?? |
Originally Posted by kj217
(Post 1575430714)
i have a 99 C5 with selective ride and it feels like skipping more than i can expect from a sports car :(
i have toggled the selective ride to all options but it doesn't feels any better (rigid),, they all feel almost the same,, am i having a problem with my selective ride (no DIC)?? is it easy to place those resistors if installed Z06 shocks?? So,,,,find some C5 Z51 sway bars, C5 ZO6 sway bars or C6 Z51 sway bars and some metal end links, toss in some new C6 ZO6 and you will have a significantly different car that you will really enjoy driving. It isn't really a significant investment either. If it were me,,, I would have the F-45 deprogrammed out of the BCM with a Tech II. The resistors are not difficult to install for someone that can solder. BC |
(Post 1575431380)
what end links you recommend,, aftermarket or take offs from better vettes? |
(Post 1575432284)
which sway bar is best among these three??
what end links you recommend,, aftermarket or take offs from better vettes? If you want NEW,, contact Gene and Patrick at www.gmpartshouse.com They have great prices on new C6 ZO6 shocks and sway bar stuff, Get their poly bushings also. BC |
What is the part # to order C6 Z06 shocks?
Gene and Patrick have the best prices
http://forums.corvetteforum.com/c5-t...rts-house.html http://forums.corvetteforum.com/c6-t...rts-house.html Z06 Shocks 10313647 – Z06 Front Shocks 25819268 – Z06 Rear Shocks Both sets of front and rear shocks, total of 4, $246.16 Use part number c6z06shocks on the website to order this kit. Z06 Sway Bar Kit 25919502 – Front stabilizer bar 20777536 – Rear stabilizer bar 10387838 (2) – Front stabilizer insulators 15262795 (2) – Rear stabilizer insulators Complete kit front and rear is $230.43 Use part number c6z06bars on the website to order this kit. |
(Post 1575432648)
Look in the used C5 Parts section or C6 parts section. Used C5 Z or C6 Z51 are excellent. Stock metal OEM end links are excellent. They are stock on the ZO6
(Post 1575457292)
i found used C6 Z51 bars with stock metal links,, do they fit directly on C5 coupe?
BC |
