What is the Best Spark Plugs for C6?
Is it NGk's like the LS1's or diffrent?
Originally Posted by corvet786c
(Post 1574893237)
(Post 1574893237)
I did a back to back comparison on Delco plugs vs NGK's in our LS2 Trailblazer SS and we lost 8 RWHP with NGK's. I still run them in the TBSS because it has a 125 kit on it, but I would not touch them in a stock car. I am running the AC Delcos in our Cammed Z06 without issue. |
Originally Posted by RichieRichZ06
(Post 1574896982)
If your car is lightly modded or mostly stock ,the Delco plugs are the best. I have seen so many driveability issues recently with NGK's installed in reletively stock cars. I have swapped out NGK's for delco plugs in over a dozen cars recently for random drivability issues directly related to the plugs. Everything from P0300 codes to carbon tracking on the plugs.
Originally Posted by theofel
(Post 1574897394)
I have a real problem believing there is 8 RWHP difference when installing any plug with the right heat range. Let's see some dyno graphs. I would love this to be true...I certainely would like to see another 8 RWHP! Better than adding a Fast intake to my Bolt-on LS3.
Im not buying it either. |
1 Attachment(s)
(Post 1574897394)
Attachment 48154655 |
Theres some other factor at work here. Dont know what it is but Im confident you're not getting 8hp with just a plug change, unless theres a gap difference, wrong heat range, bad plug or something not quite the same from test to test.
Originally Posted by NYC6
(Post 1574898211)
Gap was double checked, heat range was the same, part numbers for the application were verified etc. This is not my first BBQ ;) This is not the only time I have seen something similar. I work at a dealer and we see 30-40 forum cars a month, all with unique issues. Recently I have seen a ton of issues with aftermarket plugs and drivability issues. I only posted this for people to see facts, not some keyboard commando baised opinion with no supporting facts to back it up. Take it for what it's worth and if you don't believe it, no biggie. I am not going to lose any sleep over peoples doubts on this issue when I see it on a weekly basis. :thumbs: |
(Post 1574898149)
Here are the graphs. 1st run is baseline with stock plugs and no tune, 2nd is with long tubes, tune and NGK's, 3rd is back to Delco's with no other changes in the tune. I felt that after adding the LT's it should have picked up more so we were wondering why. We put the stock AC Delco plugs back in it to eliminate that variable and came up with an additional 8 RWHP.
http://i61.photobucket.com/albums/h7.../tbssgraph.jpg |
Originally Posted by dennis50nj
(Post 1574898513)
:iagree: that plugs brand new out of the box, diferent brands could make a big diference, im not sure on the dyno numbers but i have seen .15 gain at the 1/4 and also a loss of .30 with less then a 100 street miles on some brands:thumbs:i have never had a problem with the ngk, i always just coat the iner spark plug boots with a qtip and dielectric creme
The only reason that made me think to do this comparison was seeing so many recent issues with aftermarket plugs on Corvettes. Using that logic on the LS2 TBSS, this is what i found. The dielectric grease is a good idea to keep the boots from sticking on the plugs as well. |
(Post 1574897394)
(Post 1574898211)
In my opinion, the AC Delco plugs are just as good if not better than the other spark plugs on the market. I don't believe thereis anything to be gained by change them out to another brand including NGK for a stock or mildly modded engine.
(Post 1574896982)
Originally Posted by Mike's LS3
(Post 1574900580)
Are we talking about Delco's iridium plugs? How often should they be changed for keeping optimal performance on a stock LS3?
Depending on driving habits, racing etc, I would change them every 25k on a mildly modded engine or less frequently on a stock one. I see cars come in here with 50k-75k on stock plugs and they still run great. |
(Post 1574900580)
Did the 08 LS3's come with Delco iridium plugs?
(Post 1574900685)
Yep, the stock Iridium plugs.
I thought they were Platinum but I guess not. |
1 Attachment(s)
Originally Posted by LS1LT1
(Post 1574902833)
The factory/stock Corvette AC Delco plugs are Iridium?
I thought they were Platinum but I guess not. Attachment 48154654 |
If that dyno graph is from a LS3 with the mods you quoted...those #'s are about 60 t0 85 hp shy of what they should be! Even without mods they are 35 t0 50hp off. I'm willing to give the Delco another try when I change out my NGK tr55's. Thanks for your input.
(Post 1574908486)
Brisk USA plugs work great for me. :thumbs:
I just had longtubes and cam installed on my 08 C6. Would the delco's still be OK for this application?
