1972 C3 Engine / Emissions Vacuum Diagram
I am looking for a vacuum diagram, NOT FOR THE HEADLIGHTS, but for the engine and or emissions routing, ie distributor vacuum routing ect. I am trying to help a friend of mine. Thanks!
-=Rick |
Your friend could use the assembly instruction manual (AIM). It shows the hose routing and color codes.
:thumbs: |
(Post 1574858827)
:thumbs: Thanks, -=Rick |
Hi Rick,
Knowing which engine you're working on will help clarify what information you need. Base, LT-!, or 454? Regards, Alan |
Originally Posted by Alan 71
(Post 1574859789)
Hi Rick,
Hi Rick,
Here's a photo of a base 72 engine. 1 small hose from the vapor canister to a nipple on the front of the carb. 1 large hose from the vapor canister to the pvc valve and then to a nipple on the front of the carb. 1 small hose from the distributor can to the TCS solenoid and then to a nipple on the side of the carburetor. The third port on the solenoid has a small foam filter on it. Hope this helps! Regards, Alan http://i218.photobucket.com/albums/c...l/DSC_0720.jpg |
