????????AC Delco pf46--E??? What is the E about?
46e? What is e?
Originally Posted by Steve Doten
(Post 1574819631)
46e? What is e?
http://www.sandyblogs.com/techconnec...il-filter.html |
I am one of the largest Delco distributors in Canada....
Here is cut and paste of the bulletins... BULLETIN ACD09-154 DATE: September 2009 TO: All ACDelco Distributors SUBJECT: FILTER DESIGN CHANGE – PF46, PF47, PF52 AND PF61 Description ACDelco is implementing a design change on the PF46, PF47, PF52 and PF61 ACDelco Oil Filters due to capacity constraints on the current product design. GM engineers have approved the new design which will begin to be incorporated in upcoming vehicle designs. This OE approved and manufactured filter provides the same Duraguard filtration performance as the previous design and specifically utilizes the original ACDelco media that traps particles down to 25 microns. Additional features include a slightly smaller can, fully covered baseplate, non-metallic end caps and high strength nylon core. This newly designed oil filter has the benefits of not only bringing excellent filtration performance, it is also environmentally friendly with components that can now be easily separated into steel, oil and parts to incinerate, resulting in less waste. The Durapack versions of the newer design filter have begun shipping. The boxed or individually packaged versions will utilize the available production capacity on the original design, where possible, and will then begin to rollover to the newer design. Effective Date Immediately Order Input The current ACDelco short number will be used for the new design (interchangeable supersession). The system will automatically supersede to the new design. Boxed Version Durapack Version ACDelco # Part A/GM # Part B/GM # ACDelco # Part A/GM # Part B/GM # PF46 88984215 19210283 PF46F 89036836 19210335 PF47 25010792 19210284 PF47F 12490147 19210336 PF61 89017342 19210285 PF61F 89032612 19210337 PF52 25171377 19210286 PF52F 12490148 19210338 ACDelco appreciates your business and stands behind each and every filter that we distribute with pride and confidence. Nancy Lee-Olender Senior Product Manager |
Sorry the chart in the first reply didn't work...
Here is the next bulletin.... BULLETIN ACD09-174 DATE: OCTOBER 2009 TO: All ACDelco Distributors SUBJECT: Classic Oil Filter Design Reintroduction: PF46, PF47, PF52 & PF61 Description Earlier this year, ACDelco introduced a new OE filter design for our PF46, PF47, PF52 and PF61 oil filters. This change in filter design was implemented by our OE engineers to be used in production of 2010 vehicles and as a replacement filter for certain out of production applications. Due to the volume of vehicles that currently exist with the prior design; a decision has been made to reintroduce the original, classic design in the boxed version, for the ACDelco channel only. This will allow consumers who prefer the original design to continue to use it on their vehicles. The filters are identical to the previous design in all aspects and will carry the previous short number, i.e., PF46. The current OE design will continue to be available under the new short number "PF46E" and will carry the current long number. In summary, the changes are as follows: ACDelco has reintroduced the original version of the subject filters in the boxed version using current short numbers: PF46, PF47, PF52 and PF61 for the ACDelco Channel only. Current OE production part numbers will change to an "E" suffix, i.e., PF46E. Durapack quantities continue to be available in the "E" version, using the short number with an "F" suffix, i.e., PF46F. Classic design is not available in Durapack quantities. |
note the dates on these bulletins as they progress...
BULLETIN ACD09-187 DATE: NOVEMBER 2009 TO: All ACDelco Distributors SUBJECT: Cancellation of Classic Oil Filter Design: PF46, PF47, PF52 and PF61 ACDelco is suspending the offering of classic filters PF46, PF47, PF52 and PF61. The re-introduction of the classic filters was announced on bulletin ACD09-174, published in late October. Any orders currently in the system will be filled, and stock will be exhausted and not replenished. The newer design will continue to be available boxed from the PDC’s and direct ship from the supplier on the Durapack program. Part number summary as follows: sorry this is not copying off the PDF!! Boxed from the PDC Durapack numbers The part number packaging and labeling for these filters are being changed to reflect the ‘E’ suffix. This will be a rolling change that will occur over the next few months. The PF46E, PF47E, PF52E and PF61E are the same filters you receive today as PF46, PF47, PF52 and PF61. We apologize for any inconvenience this may cause you. Effective Date Classic filters will be available until inventory is exhausted. Nancy Lee-Olender Senior Product Manager |
Lastly, there is a bulletin from January 2010 indicating a rolling label change....
So don't be afraid of any of these Delco filters. Some distributors have one number, others stock the others! |
Good info
Thanks very much. |
means it will cost more.
Originally Posted by imavettegirl
(Post 1574825179)
I honestly don't think the price has changed in a while....regardless of packaging. It's all in how you purchase them!
I was a little confused buying my filter today. I saw that E on the end of the number, and had never seen that before. I thought I would check here to see if it is the same and correct filter, and apparently, it is.
Thanks for the info 87gtNOS. |
Originally Posted by Mr. Wonderful
(Post 1576739178)
So is the 46E better than the 46? If so, why still sell the 46? My parts store has both and at the same price.
Originally Posted by atikovi
(Post 1584918483)
I think I will keep using WIX! :rock: |
Originally Posted by TEXHAWK0
(Post 1585923585)
The "e" is for environmental friendly, and is designed to be more easily recycled. ie probably just a reason to build a cheaper filter.
I think I will keep using WIX! :rock: wow...just wow....did you even read any of this thread? :smash: |
Originally Posted by 87gtnos
(Post 1574820078)
lastly, there is a bulletin from january 2010 indicating a rolling label change....
So don't be afraid of any of these delco filters. Some distributors have one number, others stock the others! |
Originally Posted by Marcel Dube
(Post 1606456838)
does 19210285 pf61e fit a 2002 c5?
Can’t speak for you or others, but I don’t have an extra inch of ground clearance. |
