1974 Fuse Box Diagram
Anyone have a picture and/or diagram of the fuse box inside the car. I am blowing the 20A fuse right below the "gauges" fuse, but on my box the name for that fuse is broke off so I don't know what it is. :cheers:
thats the RADIO-TCS sol fuse
how do you know when its blown-what is not working ? |
Originally Posted by ...Roger...
(Post 1574715393)
how do you know when its blown-what is not working ? A couple of days ago I go out than turn the ignition to show a friend the radio and it has no power. I look at the fuse box and that fuse in question is fried. I disconnect the negative terminal on the battery, change the fuse, reconnect negative and instantly the fuse is fried again. I disconnected the radio wiring from that yellow wire and tried changed the fuse again, bam, same result. So something is overloading that fuse, I just don't know what. And what is the TCS sol??? |
TCS= transmission controlled spark=emission crap (IMO)
On that fuse is radio,TCS wiring,relay,solenoid etc,hood scoop fresh air fooler solenoid and pedal switch. Bubba's wire cutters will clean that circuit up nicely. :yesnod: edit- carb solenoid is also on that circuit. |
(Post 1574718401)
(Post 1574718401)
On that fuse is radio,TCS wiring,relay,solenoid etc,hood scoop fresh air fooler solenoid and pedal switch. Bubba's wire cutters will clean that circuit up nicely. :yesnod: edit- carb solenoid is also on that circuit. Forget the POR-15 black heat paint, everything on that #340261 1974 intake manifold is absolutely stock and emissions-compliant. http://img.photobucket.com/albums/v1...y97/TCSB-1.jpg |
