My list of Diagnostic Codes - Check Engine JUST came on!
Hey All! My check engine light came on last night as I was driving, even though the car really didn't feel any different, i'm lead to believe that it's definitely an issue I should look in to...just because. (I'm not one to think "Oh, it's just the oxygen sensor").
Anyways, I understand that the "H" and the "C" in the diagnostic codes represent "Historical" and "Current"...and there was only one "C" code...at the same time, there were several codes that I wasn't able to decipher. Could someone translate them for me? Additionally, can you guys lend some insight as to how to fix these codes and if the check engine light is the result of the current "C" code? Thanks in advance! CODES: 10 PCM: P1415 H C - Secondary Air Injection (AIR) system bank 1 40 BCM B2578 H - Right Turn Signal Monitor Circuit B2583 H - Left Turn Signal Monitor Circuit AO LDCM: B2206 H - Right Window Up Switch Circuit B2282 H - Battery #1 Circuit B2284 H - Battery #2 Circuit U1064 H - ????? A1 RDCM: B2283 H - Battery #1 Circuit B2282 H - Battery #2 Circuit B2263 H - Horizontal Position Sensor Circuit B2265 H - Vertical Position Sensor Circuit U1064 H - ????? BO RFA: U 1096 H - ????? U 1064 H - ????? U 1016 H - ????? 28 TCS: NO CODES 58 SDM: NO CODES 80 RADIO: NO CODES 99 HVAC: NO CODES A6 SCM: NO CODES |
Please CLEAR the DTCs.... Thats just too many to try to sort thru. I bet ya that when you clear all the DTCs NONE come back except maybe the 1415 DTC. :thumbs:
Thats going to require the AIR Check valve to be replaced. A weak battery or disconnecting the battery can and will cause all those history DTCs |
Hey Bill! I'd love to, but my lack of knowledge is keeping me from doing so, especially with the U codes that are undefined. I've changed the battery over the winter so i'm not too worried about some of the battery codes.
It definitely is a lot of codes, no denying that! |
Originally Posted by CharlieB1979
(Post 1574618983)
It definitely is a lot of codes, no denying that! http://www.c5forum.com/ayc/dtcdic.php http://farm5.static.flickr.com/4081/...9f3e9753_b.jpg |
It's definitely not that I don't know how to reset the codes...I do know how, it's that I want to make sure that none of them are critical codes before I start resetting things. Thanks for that excerpt, lucky...it brings me a bit closer to understanding what those "U" codes are...just gotta figure out the significance of them is all.
Charlie
You will quickly figure out if a DTC is critical,,,it will come back and come back with a vengence!:yesnod::lol: Just clear ALL of them and work on any that show back up. :thumbs: BC |
:iagree:
Done and done, guys. I'm gonna go get the check engine light checked out too...really curious as to what that's all about, probably just an O2 sensor (grumble). Okay, taking your guys' advice! Thanks again!
Just had to deal with the P1415 over the weekend, seriously only a 10 minute fix once you have the new check valve.
