Replace Dash Lights with LED?
Hi All,
A suggestion was made to me in another thread about replacing my dash bulbs with LED while I have the dash out. This sounds like an attractive idea. Curious who has tried this and what their thoughts are? I found these, prewired for under $1.50ea... http://www.oznium.com/prewired-leds |
funny I was told the same thing. Just have not gotten around to doing it yet. I have read other threads and the opinion is to use SMD LEDs. The produce more light and do a very good job with the dash gauges. The come in blue, white, and red. I was considering doing it blue just to be a little different.
Originally Posted by eagle275
(Post 1574529390)
Just to be clear, your other thread was about the blue wire heating up , LEDs will not help with this problem.
Also one other note , I have read some LEDs will not allow you to use the rheostat function of your headlight switch. ..................:cheers: |
Thanks Roger. I started that other thread to try to avoid confusion. I was thinking that the LED's would help avoid heating the wire due to less current draw...
Originally Posted by Dantana
(Post 1574530451)
The LEDs in the INST lights could reduce the draw on the dk green wire circuit however. The lt blue wire circuit is just for the headlamps , do you have anything other than the 4 HL bulbs on the circuit , like maybe some foglamps or are you running all 6 filaments on your headlights instead of the max of 4 filaments the factory intended ? ( I seem to remember you did some fancy wiring awhile back .) |
Originally Posted by ...Roger...
(Post 1574530271)
. You can't effectively dim LEDS with a rheostat. The rheostat varies the voltage to the light bulbs. A variable voltage works for incandescents. For LEDS, you need to vary the current to effectively dim them...not the voltage. It's a little complicated to explain. It has to do with the LEDS being diodes operated in their saturated part of the I,V curve. Think I"ll stop here!! |
I put LEDS in mine and have been very happy. I bought them from superbrightleds.com. As far as dimming goes, no idea, never bother to adjust them.
I've ordered some SMD LED's that fit into the 1895 sockets in blue. Hopefully they will arrive this week and I can post some pics after installing this weekend.
(Post 1574538887)
I ordered these because they are supposed to fit intot he 1895 dash sockets:
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT Roger, I just caught your post about all the wiring on my C3. I've done quite a bit (electric fans, amps, MSD, fixing my harness) but I haven't tapped intot he headlights for anything that I can recall. I'll go over everything this weekend to make sure. Great thought. |
(Post 1574541344)
Not me, Roger. Interesting idea though.
(Post 1574542072)
Originally Posted by 68/70Vette
(Post 1574536035)
..<snip>...
You can't effectively dim LEDS with a rheostat. The rheostat varies the voltage to the light bulbs. A variable voltage works for incandescents. For LEDS, you need to vary the current to effectively dim them...not the voltage. It is possible to retain the original dimmer knob too if you know your way around a soldering iron and dmm. |
Originally Posted by sabre1981
(Post 1574536115)
(Post 1574536115)
mine were $7.50/pair ($3.75ea) See my link above. They are 5 way, take a look at the pic on the other end of the link
Plugged in all my LED bulbs today and fixed the sockets in the console. I closed the grage door for a minute and they look great. Not quite as bright as I thought they would be though. Looking at them outside the dash they practically burn your eyes but inside the clusters they are very subdued.
When I get the dash back together I'll put up some pics. |
