Rear end gear ratio for big block
After searching through several posts reguarding the rear gear ratios I'm a little confused as to what rear end gear I should use. The vital info follows:
1975 coupe zz502 (5800 redline) Turbo 400 trans (I believe 3rd gear is 1:1) 2800rpm stall converter 275/35 R18 tires (these are 25.57" diameter) Tread width: 10.8" I will drive this car on sunny weekends and at the drag strip on occasion. So the zz502 puts out a lot of torque... http://img.photobucket.com/albums/v3...d/12371171.jpg Would this suggest a lower gear like 3.08? I currently own two gears, 3.08 and 3.90. If I install the 3.90 then I'm looking at 3587 rpm @ 70mph (seems high) and will red-line at 113mph (based on my understanding the T400 is 1:1 in 3rd gear). That 3.90 gear is too tall right? What gear would you run? |
What gear is in it now?
I have the same motor as you but a 4 speed trans and will be replacing the current 3.55 rear with a 3.08 |
336....jmo....:thumbs:
I run with M21, 3.08 behind a 528hp/564 ftlb 489 - with 285/40/18's it cruises 70mph close to 2600 rpm - its fine off the line too :thumbs:
You won't like the 3.90s...the stock zz cam is done by 5200-5400 rpms and with 3.90 gears, you will be out of steam before the end of the 1/4.
I would stick with 3.36s or 3.08s since you have them. The converter will do more for you then the gears anyway. I have a 496 and have 3.08s. It's highway friendly and the BB torque combined with a good converter pulls them fine. That being said, when I rebuild the IRS I am going to 3.36s for a little better ETs and street grunt. |
Thanks AJ and thanks to others who have replied.
roscobbc, your tires are 1.5 inches taller than mine. I'm not sure what the final output ratio of the M21 is. Thanks for the input. AJ, what transmission you running? |
Originally Posted by Red_Shift
(Post 1574392534)
roscobbc, your tires are 1.5 inches taller than mine. I'm not sure what the final output ratio of the M21 is. Thanks for the input. AJ, what transmission you running? Just make sure you use a good converter, not a speed shop cheapy as they tend to slip way too much at all speeds and hurt trap speed.. |
308 for sure.
