Pedal Covers?
I've noticed that when I wear some dress shoes ( w/leather soles) the pedals feel a little too slick for comfort.Also sometimes when my shoes are wet it feels the same.
Has anyone found any covers that fit & work? Thanks ns3 |
I had the same issues until I picked up these from CCA.
http://i53.photobucket.com/albums/g4...m/P1000333.jpg |
:iagree: good lookin as well
Originally Posted by 87SAM
(Post 1574226354)
Two pedals need to be rough, Clutch & Brakes, they should have sharp points to stick to your shoes.. Gas pedal needs to be slippery, so you can adjust your foot without jamming the pedal. The dead foot, can be anything, it's just a rest... Not sure if you track your vehicle, but if you do and you need to heal/toe the brake and gas then the above applies.. Good luck.
Tks Guys :thumbs:
I have a new batch finishing up the middle of the week :cheers: Peace Chip |
(Post 1574226354)
http://i53.photobucket.com/albums/g4...m/P1000333.jpg Christian |
Originally Posted by Jesse Asis
(Post 1574228856)
Do they have those for automatics!!
Originally Posted by miami993c297
(Post 1574230925)
Is this set an Auto X one???
Christian Peace Chip |
Originally Posted by corvettedaddy11
(Post 1574231321)
Peace Chip |
They look great.. How hard are they to install? Do I have to remove the old petals or do they go over the current ones?
Thanks again. Bob |
Those do look good, Chip. :yesnod:
Originally Posted by Willfulone
(Post 1574233436)
Yup,
Peace Chip When will you be able to ship a set to Florida? Christian |
(Post 1574237480)
Hi Chip,
When will you be able to ship a set to Florida? Christian I'll have the new Manual Grid Sets in by the end of this week. They will ship Friday or Monday The Holiday is messing us up a day or two Peace Chip |
Originally Posted by bobsride
(Post 1574235509)
Thanks again. Bob Check out this install instruction link http://www.customcorvetteaccessories...edalsinst.html I'd give it a 2 on a scale of 1 to 10...My 13 yo does them for people all the time :thumbs: Peace Chip |
I put these on from CCA. Solved the slipping issue.
http://i490.photobucket.com/albums/r...08/Pedals1.jpg |
(Post 1574238662)
Hi Christian,
I'll have the new Manual Grid Sets in by the end of this week. They will ship Friday or Monday The Holiday is messing us up a day or two Peace Chip I just placed an order through your Website... Christian |
(Post 1574228856)
MSG C5, only if the block finish grabs your sole of the shoes. If the gas pedal sticks to your shoes. Your heal should be planted and as you step forward on the gas pedal the pedal and contact of your shoes changes or slips, this is the only pedal that should slip under your foot. This allows micro adjustment of the pedal since C5 has electronic wire throttle it is very senitive to pedal movement. A sticking pedal will jerk and casue problems... I made that mistake 20 years ago on my 280ZX (purchase a grippy pedal cover), I took that off in 2 days and left the plastic stock one there. If you notice your stock C5 pedal is smooth with lines going top to bottom, no chance of sticking. Good luck.
