FS-NEW GM "Hot Cam" 12370846
Taken off NEW ZZ383 long block...
$200 PLUS shipping... Hydraulic Roller Cam - 222/230 duration - 509/528" lift This hydraulic roller design contains eccentric for mechanical fuel pump. The duration at .050" tappet lift (intake/exhaust) is 222/230; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 509/528. Valve lash is zero/zero and lobe centerline is 112 degrees. |
ttt
ttt
ttt
pics? and will this be fine for a 350?
Originally Posted by phildawg19
(Post 1574131667)
