1980 vacuum hose diagram and kit
I need a diagram for the entire vacuum line setup on a 1980 vette. Where can I find one? I can find the headlight but thats not what I need. Its time to replace all the lines. Also who sells a full vacuum line kit?
Also, what are the major components that I need the vacuum lines for? Trans, carb, headlights, brakes, cruise control... what else? |
anyone?
This should help,if not search the Willcox site ,he has most of the vacuum diagrams.
http://willcoxcorvette.com/instructi...82_secured.pdf |
Originally Posted by glarior
(Post 1573850576)
Also, what are the major components that I need the vacuum lines for? Trans, carb, headlights, brakes, cruise control... what else? http://www.docrebuild.com/dr-r-web/EMISS-HOSE.HTML |
If you are doing a restoration You will want a correct kit and not just any kit. Dr Rebuild if I remember corectly in NY makes as good of Kit as anyone. The diffrence is how the Hoses are Striped. If its not a restoration any Kit will do. Most of the major Vendors sell the above kit if you tell them what your doing. Some of the more detailed diagrams have the Hoses wrong for the 80-82 at the headlights. The 80-82's have the Vacume cans opposite. The left can is on the right and the right is on the left.
Originally Posted by KENS80V
(Post 1573856735)
Originally Posted by Gale Banks 80'
(Post 1573859853)
I can hear the leak on my 1980 at the vacuum select switch, hoses seem to tbe ok. Should replacing the switch solve the problem
Originally Posted by twk1946
(Post 1583395227)
It is the best link I have found to troubleshoot vacuum on the vette. |
