Corvette V12? The BUILD....
If you've been around a while- you've seen this one-
A Pacecar w/ a Jag V12- https://cimg9.ibsrv.net/gimg/www.cor...e67e31bc6e.jpg https://cimg2.ibsrv.net/gimg/www.cor...cddac96612.jpg Boy-this guy gets flamed.... http://forums.corvetteforum.com/c3-g...h-the-v12.html And here's my idea/ project a BMW V12- NO frame mods/NO firewall mods/ Stock motor mount bolted to a mount I made that bolts to the stock V12 block mounts- Will even fit under a small block hood.... https://cimg2.ibsrv.net/gimg/www.cor...6727f7bff7.jpg https://cimg5.ibsrv.net/gimg/www.cor...d17ff42290.jpg https://cimg6.ibsrv.net/gimg/www.cor...d36a0df15a.jpg It fits- w/ no real issues- https://cimg5.ibsrv.net/gimg/www.cor...a95a40cb00.jpg https://cimg6.ibsrv.net/gimg/www.cor...cbdc1a6c1e.jpg What do you think??? Or Flame away...... Richard |
It's definitely something I've never seen done. I wouldn't do that to my Vette. He should have just built his original engine.
That is one of the coolest swaps I've seen. I'd do that in a heartbeat if I found that engine before I built mine. Is he able to run a manual transmission behind it?
Jag V-12's are nice but down on power compared to a small block Chevy.
GM did try a Falconer V-12 in a C4. 601 cubic inch, 660-horsepower and 782 ft./lb. of torque. http://www.corvettereport.com/corvet...ette/#more-799 http://www.corvettereport.com/wp-con...12cylinder.jpg |
Originally Posted by SteveG75
(Post 1573807672)
[/IMG] However- the BMW V12 I'm gonna run with weighs in about 500lbs- fully dressed - A little more than a LS1. As far as power goes- About 300HP in stock form. I've pulled all the accessories (A/C & P/S) and setting it up w/ a dry sump-a little clean up and I really will only see about 350HP. So- really close to what my original LS-5 made back in the day. Hauq- Manual transmission is not a problem- The BMW 850's came w/ a 6 speed-and they are not too tough to find. Richard |
Can you get it to 850CSi trim? :D
Originally Posted by Richard454
(Post 1573807087)
That's pretty cool for sure. I'd like to hear the exhaust note on the thing.
Originally Posted by gerry72
(Post 1573808391)
You should go for it and set up a thread to show us your progress on the way. Sounds like a lot of fun!! :cheers:
It's :cool: but the low HP would deter me :cheers:
go for it and post progress pics.
I bet it will sound awesome
i like it!
Thanks - I will keep the pics coming
Originally Posted by MotorHead
(Post 1573808929)
Very few can say they have a V12!!!! As far as more HP-or 850 CSI motor- it gets expensive $1300 cams times two...Stroker crank $4000. Chips are $400 but only worth 30HP. I got the motor out of a 1990 750IL - on the cheap- I bought the complete car for $700 (yes-Running and driving- original paint never wrecked) https://cimg2.ibsrv.net/gimg/www.cor...2c5799f3a2.jpg Here's one of the swaps that gave me the idea- Is a Datsun 240/280Z w/ a GTO replica body on it and a BMW V12 powering it- https://cimg2.ibsrv.net/gimg/www.cor...2d66d3368e.jpg https://cimg3.ibsrv.net/gimg/www.cor...18359cccaa.jpg |
When putting that BMW V12 in, there got to be a lot of electrical work to be done? Much more than putting the engine in?
Should have been a CSI engine but i suppose thats a lot more $ |
Actually- thanks to reading the Lambo Kit Car building forms- these guys have mapped out all the wires. I'm using the stock computers (1 for each bank of 6cyl and one that syncs them-3 total).
Before I pulled the motor - I clipped wires and made sure everything worked correctly- I even wired the electronic throttle under the hood and made sure it worked- Electronic throttle- http://i51.photobucket.com/albums/f3...5/P1010248.jpg In addition to the six wires for the drive by wire throttle- have only 3 check light bulbs to wire- power/switched ignition/ ground and fuel pumps (2). It's really not that tough. The dry sump has also been done before- BMW uses a two part oil pan and I just have to cut a piece for the lower pan- add some hoses/pump and tank. http://members.core.com/~sysadmin/personal/BMW_oila.jpg http://members.core.com/~sysadmin/personal/BMW_oilf.jpg http://members.core.com/~sysadmin/pe...-drysump10.jpg |
(Post 1573810421)
Everywhere I go- Somebody will always say/claim they (or a buddy/cousin/neighbor- etc) has more horsepower.... Very few can say they have a V12!!!! As far as more HP-or 850 CSI motor- it gets expensive $1300 cams times two...Stroker crank $4000. Chips are $400 but only worth 30HP. I got the motor out of a 1990 750IL - on the cheap- I bought the complete car for $700 (yes-Running and driving- original paint never wrecked) http://i51.photobucket.com/albums/f3...4/P1010225.jpg Here's one of the swaps that gave me the idea- Is a Datsun 240/280Z w/ a GTO replica body on it and a BMW V12 powering it- http://members.core.com/~sysadmin/pe...O_07_0023a.jpg http://members.core.com/~sysadmin/pe...O_07_0070a.jpg Bee Jay |
(Post 1573810421)
:cool: :cheers: |
Originally Posted by Ganey
(Post 1573812187)
V-12s are cool, but it's power & performance that counts!!!!!!!!!!
:cool: :cheers: :cheers: Rick B. |
