zo6 tire size
I have a 97 vet with zo6 rims. I'm currently running 295/35 18 on the back. Will a 295/30 18 work?
If you go to the Tire Rack website and search for tires by size you will find most manufactures recommend a 10-11 inch rim size for that tire. Yours' should be 10.5's so you should be fine :thumbs:
tires
Thanks for the help. I found a set of hankook tires that are 295/30 18"
and wasn't sure they would fit, not to sure what the 30-35 on the tire refers to. |
Originally Posted by leo97
(Post 1573490500)
(Post 1573490500)
Originally Posted by wamara
(Post 1573491500)
Your car doesn't have AH, so if it becomes less than that of your front tire, I don't think it will impact your traction control.
Active Handling is unaffected by tire height changes. Traction Control is affected, and yes his 97 has it. I would not run the 295/30/18 on the rear, as your chances of finding a shorter front tire (in either 17 or 18" size) are quite slim....and you need to keep the rear tires taller than the fronts to avoid unwanted traction control intrusion. :cheers: |
[QUOTE=Y2Kvert4me;1573492649]You got that backwards...
Active Handling is unaffected by tire height changes. Traction Control is affected, and yes his 97 has it. Tom, Not trying to get into an argument here, but why are you saying the AH doesn't get impacted if the rear tire circumference is less than the fronts? I thought this has been a perennial topic here :confused: As to traction control, how would the change in the front to rear tire circumference ratio affect the TC? Isn't the TC just a function of what is going on with the left rear wheel and right rear wheel? How do the front tires play a role in this? |
(Post 1573495079)
Originally Posted by Y2Kvert4me
(Post 1573492649)
Active Handling is unaffected by tire height changes. Traction Control is affected, and yes his 97 has it. Tom, Not trying to get into an argument here, but why are you saying the AH doesn't get impacted if the rear tire circumference is less than the fronts? I thought this has been a perennial topic here :confused: As to traction control, how would the change in the front to rear tire circumference ratio affect the TC? Isn't the TC just a function of what is going on with the left rear wheel and right rear wheel? How do the front tires play a role in this? When the rears begin to turn faster the fronts, it is an indication of lost traction, TC intervenes and cuts power. Mounting shorter rear tires effectively increases sensed rear wheel speed. Keeping tire heights proportional front to rear is very important for this reason. Active Handling monitors steering position, and car direction. When it senses the car is traveling in a direction different than that of what the steering wheel is pointed towards, it assumes the car is in a skid, and applies braking depending on which way the car is sensed to be skidding. It does so through the yaw and steering wheel position sensor. :cheers: |
tires
Thanks for the info everyone. I knew someone could help answer my question... I didn't want to buy the tires without finding out about the size. I thought the last number had something to do with the profile.
Thanks for clearing that up :crazy: |
Tire sizes work like this...
295/35/18 295 - width of tire in mm. 35 - sidewall thickness, expressed as a percentage of width. The sidewall dimension is 35% of 295mm in this example. Many people don't understand this, but as you can see, a wider tire with the same profile number also become taller. 18 - The wheel diameter (in inches). :cheers: |
