Service Tire Monitor System
Hello, from drageOCCA,
I'm newly registered to this site. And would like to get information on my C5 displaying a message that reads Service Tire Monitoring System. I did see someone else with this same issue. Any advice on self repair would be appreciated. After previous dealership service tech's who don't know what they are doing - I refuse to ever take my vets to a dealership for repairs. After owning C3,C4 and now C5, I've become extremely good at doing my own sevice work with the assistance of some qualified mechanic friends. :chevy: |
You are probably going to need new sensors. First, drive your car and check your DIC and see which tire is reading "XXX". Then try re-training them. Do a search in this forum to find the write up. Then if it still tells you to service the tire monitoring system, you may have to replace the sensors in the tires. Fortunately, you have the cheaper sensors to replace. There are several sources for new sensors, several tire stores and Costco sell them as well as some of the supporting vendors here. You will have to break down the wheels to get to the sensors so a tire shop would be advised. Good luck... :flag:
New or rebuilt sensors will fix up right up.
Here is the procedure. Plus some helpful sites
https://www.corvetteforum.com/techti....php?TopicID=1 http://www.stengel.net/diccodes.htm 1) Turn ignition on ( TO reset tire pressure monitor Procedure ) 2) Press "Reset" button in order to clear any IPC display warning messages 3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank 4) Press and hold the DIC "Reset" button for 3 seconds 5) Press the "Options" button again until TIRE TRAINING message appears 6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming 7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem 8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over) 9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point. :ack: |
I had the same issue but thanks to the awesome instuctions from HG in bel air,md-it worked!! thanks a million and it probably saved me a few bucks by DIY-----
Tire sensors work
Originally Posted by Bakersfield
(Post 1573408070)
Originally Posted by Mark Gardner
(Post 1602451550)
All the tires read so what senses the tires must be bad.
(Post 1602451550)
(Post 1602452228)
I am getting the signal to service tire monitoring but all my tires are reading tire pressures correctly No xx.
Originally Posted by drageOCCA
(Post 1573407817)
I realize I’m resurrecting an old thread, but I followed the procedure listed above but the LF sensor doesn’t respond to the magnet while the other 3 do. Any advice?
Can't promise you it will work, but I had a similar issue. Replacing the battery fixed it (and a few other issues as well).
with any modern device that runs on battery power, the usual problem is a bad battery. I have had entertaining talks with service techs who tell the not uncommon tale of people , before they were wall mounted, bring in TV sets for repair when the problem was dead batteries in the remote.
Are we talking about a battery in the TPM or my car battery? It’s a Duralast Platinum about 2 years old so I don’t think it’s that.
Moved to C5 Tech.
The only way to replace the tpms battery is to replace the tpms. Since 3 are reading, it is probably that one sensor. As I understand it, they are designed to last about 10 years. So if they are original then the sensor just needs to be replaced. If the car battery were bad, then it would seem none of the sensors would work.
would it be better to just replace them all? Maybe I’m on borrowed time anyway.
Are there particular brands that forum members prefer? |
probably borrowed time. I just did all four as well. The front two were out. I used the schraders which were original equipment and worked great in my 02.
https://cimg5.ibsrv.net/gimg/www.cor...dd6c56d54.jpeg |
BTW- A 'safety feature' of the 1998 C5 and Tire Pressure Monitor System (TPMS) is that the computer will limit the vehicle speed to 55 mph if it cannot read tire pressure from a sensor.
