How much does your C6 weigh?
How much doe's your C6 weigh without the driver?
Has anyone actually weighed their C6. |
According to the GM site
2010 Coupe 3,208 lbs 2010 GS Coupe 3,311 lbs 2010 ZO6 3,175 lbs 2010 ZR1 3,333 lbs |
Originally Posted by chazc6
(Post 1573077802)
Has anyone actually weighed their C6. Curb weight, lbs. (kg) Coupe, 3208 (1455) Vert, 3221 (1461) GS Coupe, 3311 (1502) GS Vert, 3289 (1492) Z06, 3175 (1440) ZR1, 3333 (1512) |
I weighed my 08 3lt Z51 car the last fall with 3/4 tank of fuel + 15lbs personal stuff+2 rolls of dynamat installed in the rear area..3280lbs
A friends C5 Z06 with same fuel was 3160lbs |
Originally Posted by calmtgguy
(Post 1573078082)
For 2010 Models,
Curb weight, lbs. (kg) Coupe, 3208 (1455) Vert, 3221 (1461) GS Coupe, 3311 (1502) GS Vert, 3289 (1492) Z06, 3175 (1440) ZR1, 3333 (1512) In you above numbers, base model difference is "only" 13 lbs. But in the GS versions, the difference is the other way with the coupe weighing a whopping 22 lbs. more!!! |
For my 2010 4LT with a full tank of gas:
Scale weight -- 3300# Front axel -- 1700# Rear axel -- 1580# |
I'm sure I've seen a thread like this before where the Z weighed in just over 3000lbs...something like "3080lbs" comes to mind and I can't say how much fuel was in the car but it sounded technical.
Red Cell.:cool: |
Originally Posted by rm50
(Post 1573078043)
2010 Coupe 3,208 lbs 2010 GS Coupe 3,311 lbs 2010 ZO6 3,175 lbs 2010 ZR1 3,333 lbs The coupe can be around 100 pounds heavier with say a 3-4 lt |
About 200 lbs less without me in it. :rofl:
Otherwise 3280 if I remember right with about 1/2 a tank of gas. |
I had to put mine on a diet. It was eating up every Mustang in sight. :rofl:
Originally Posted by AORoads
(Post 1573079188)
Interesting stats, Les! Used to be the vert was 26 lbs. more than the coupe.
Originally Posted by ProudAmerican
(Post 1573082732)
I have a piece of advertising literature for the 2006 Z06 that indicates the weight is 3,132 Lbs.
Does it matter -are you going to sell your's or not buy if over a certain weight?
Originally Posted by RtStuf
(Post 1573083530)
The GM certificate of origin that came with my 2009, Z51, 1LT with NPP says 3172.:thumbs:
My shipping weight was 3198 lbs with 1/4 tank of fuel.
2008 Coupe 2LT Z51 NPP 6 speed manual |
Originally Posted by Stvr
(Post 1573086026)
(Post 1573086604)
2008, 1LT, Z51, MZ6, NPP, QX1, shipping weight 3,174 lbs. So much for a Z06 being lighter.;)
Just under 3120 with a little more than a 1/4 tank
