GR70 15 new tire match
i know corvette went to a 225 70 15 in 78 which replace the GR70 15. a lot of people say that that size work for the FR70 15. my car has HR60 15 right now which would be about a 255 60 15, looks good but for ncrs judgeing would a 235 70 15 or a 245 70 15 be a closer match for the GR70 15 than the 225 70 15.
looks like the P205 70 15 was for the FR70 15 so the P225 70 15 would be the wright match for the GR70 15 different opions still wanted
1973 cars switched to GR70-15 which is 225-70-15 prior to 1972 they were f70-15 which is 215-70-15
Originally Posted by Barry O
(Post 1572942159)
Originally Posted by silver 1
(Post 1572941516)
If you have H series tires on your car currently and drive the car at all, I would find a replacement for them soon. As you state, P-metric tires have been in use since 1978, which makes your H series tires are 30 years old. Tires older than 10 years are usually not concidered safe for use at highway speeds. |
An "F" width tire is equivalent to a 215 mm for a radial tire. "G" is 225; "H" is 235....etc. You can spend big buck$ on stock "looking" tires from one of the specialty tire outfits...but the date codes, etc. won't be correct so that is probably overkill. 60 series tires look better on the C3 Corvettes, anyway. Just put RWL, 235R60-15's on it and get docked a few points. It'll look :cool:, won't it? :thumbs:
yes the tires on my car been on her since before 1980 i was looking at tire rack and they said a p225 70 15 for the GR70 15 and a P205 70 15 for the FR70 15. i know that in 78 the changed vettes to 3 options a P225 70 15, P255 70 15 and a P255 60 15. i think my HR60 15 are close to the p255 60 15. for looks i would do a P255 60 15 but for showing i think i'll go with the P225 70 15 thanks for the opions.
(Post 1572949133)
Strangely enough, the 78 sales brochure lists a P225/60R15 white lettered tire as the optional tire, but this is a misprint. The only optional size tire offered was the 255/60, not a 225/60, the option code for this tire was QBS. |
my car is a 77 i was using the 78 tire sizes to try to match up something i got the 3 different tire sizes from c3 corvette land which had the 2 sizes u said + a P255 70 15 white letter which could be a misprint i guess it should be P225 70 15 white letter ok thanks
Silver 1, 225/70/15 is correct. 255/60/15 was a later appearance option at the time. Both about same dia. & will work.
'76's Tires
[B]I have been using 255/60-15's for about twenty years.
They look virtually stock, and have a good footprint. But even these are getting harder to get. Hummm........I wonder if my Camaro's 20"ers will fit....... |
Originally Posted by CorvetteRon
(Post 1578651945)
They look virtually stock, and have a good footprint. But even these are getting harder to get. Hummm........I wonder if my Camaro's 20"ers will fit....... Whats up with that?? |
225/70R-15 -won't fit in my '69 spare holder
Originally Posted by 7T1vette
(Post 1572946178)
I'm wondering why you recommend the 235R60-15. It may look right on he car but I doubt it will fit in the spare tire tub. I just purchased a new G225/70R-15 and mounted it on a new 15x8 rallye rim, and my '69's spare tub won't close. I 'd measured the old Goodyear GR70-15 that's still on the original spare rim, and it's section width measured 8-7/8". When I checked the 225-70R-15 specs, it shows a 9" section width. However, the mounted and inflated dimension shows 10". So I'll have to deal with either replacing the tub hanger bolts, or adjusting them - if they have the thread length. |
