Driver seat moves and seems loose
My drivers seat moves back and forth about a quarter inch and seems to be loose. Does anyone have this problem and what needs to be done to fix this?
Thanks in advance!!! |
Originally Posted by CHRIS COVE
(Post 1572872192)
Thanks in advance!!! here is one of many threads..........http://forums.corvetteforum.com/c5-t...oken-also.html |
There are two potential problems with the seat. One is that the rubber pads in the for and aft screw drive have deteriorated. These can be replaced and there is probably information in the sticky at the top of this tech section. The second problem is looseness in the front tilt mechanism. This is harder to fix but possible with more effort.
Thanks to both of you for the help. I just bought the repair kit from Zip Corvette.
(Post 1572872653)
Originally Posted by pewter99
(Post 1572872670)
:willy: shoulda done the rocking seat fix for under $1.00
I have fixed mine twice and it returns... maybe the nylon washer trick isnt tough enough?? I am not a big guy whatsoever
Its best to have someone sit in your seat while you inspect all the movable joints and brackets. Heres EVERYTNING that I have been able to gather on seat repairs:
- Seat Repairs! (LOTS OF POST!) http://forums.corvetteforum.com/c5-t...e-for-fix.html - http://forums.corvetteforum.com/c5-t...stic-part.html - http://forums.corvetteforum.com/c5-t...cs-inside.html - http://www.lieblweb.com/c5seatfix.html - http://forums.corvetteforum.com/c5-t...-seat-fix.html - http://forums.corvetteforum.com/c5-t...al-issues.html - http://forums.corvetteforum.com/c5-t...ow-to-fix.html - http://forums.corvetteforum.com/c5-t...at-either.html - |
Originally Posted by esemes
(Post 1582841325)
Originally Posted by $$$frumnuttin'
(Post 1582841976)
that sucks:ack: I keep putting this off year after year. one question I have is, can't we just fill the rubber washer area with epoxy, let it cure out, instead of taking everything apart?:lurk:
I did the nylon bushing repair six years ago and haven't had a problem since.
Charlie |
here is the best fix, sell your seats, and buy aftermarket upgrades :rock:
everything else is putting lipstick on a pig ;-) |
