-   C6 Corvette General Discussion (https://www.corvetteforum.com/forums/c6-corvette-general-discussion-74/)
-   -   Odd clicking noise in dash (https://www.corvetteforum.com/forums/c6-corvette-general-discussion/2509558-odd-clicking-noise-in-dash.html)
65GGvert 01-18-2010 08:03 AM
New to the C6, I have an 08. Is it normal that a clicking noise comes from the dash somewhere everytime you change a setting in the DIC, or press the acc button, and several other functions? It almost sounds like contacts making and braking. Sounds like it's behind the radio. I haven't tried any others, but I figured you guys would know.
glenB 01-18-2010 08:17 AM
Sounds like one of the vent actuators have failed.
Chris3 01-18-2010 08:27 AM
On mine-09..I here a stadic noise when Iam pressing the acc button..it seems like it is also comming from behind the radio.
I was wandering the same thing..is this normal?
SinisterC6 01-18-2010 11:38 AM
the static is coming from the center speaker atop the dash
diverdan 01-18-2010 12:01 PM
The clicking you are hearing is probably normal and is just part of how the car is designed. This has been discussed a fair amount around here.
steve miller 01-18-2010 12:44 PM
I've heard the clicking noise u describe on a few of the C6's I've owned. You'll get used to it.....:thumbs:
car2fast4you 01-18-2010 03:25 PM
If the clicking only occurs before you start it up, it's the sensor syncing with the fob, I believe.
okie08vette 01-18-2010 03:30 PM
Sounds like just some on the normal noises my 08 makes, they are kiind of loud. I know they can make a electronic relay that would be quite.
I really wish I could but the car in acc mode with the key fob though.
SinisterC6 01-18-2010 04:15 PM
op - sit in the car with the door closed and everything off, make sure is completely silent. press the brake pedal, did you hear a noise? how does it compare to the noise your asking about?
65GGvert 01-18-2010 09:52 PM
That's the same noise I'm talking about. It happens with several different functions, including programming options in the DIC. It's just a series of clicks that sounds like relays It's not static in the speakers and it's not in the A/C vent actuator. It's an electrical click the same as the click you hear when you press the brake without the car running. It also does it when I open the door with acc off, if I recall correctily.
Red Cell 01-18-2010 10:01 PM
:iagree:
100% accurate.
Red Cell.:cool:
LS WON 01-18-2010 10:05 PM
The clicking sound I hear is when car is idle sometimes it goes on sometimes off. Probably normal as it has been doing this for 4 years now.:lurk:
SinisterC6 01-18-2010 10:35 PM
the fuse box is located in the pass footwell, your hearing the different relays coming on - totally normal
George's_Vette 01-18-2010 10:43 PM
Ahhh the rewards of working in turbine helicopters for over a decade. WHAT'S THAT YOU SAY? Clicking, I don't hear no clicking.
Seriously my 2009 does not make any clicking noises from the dash area. It does however make a God awful metal on metal grinding noise from the tunnel when cold for the first few miles till it warms up..
I'll trade you noises?
George
Twisp, WA
surfbug 06-08-2017 10:59 PM
i was wandering what this was. The clicking was not driving me crazy...but just had me wondering
So i did thw above test. Sound is exactly the same. Now what?
Big Al
2008 c6 ls3 lt2 A5
Jerry0 06-09-2017 05:49 AM
Just had similar situation on my 05/c6(helpful members of forum guided me thru with GREAT advise)
does it happen just when starting (normal) or continue while braking possibly?
As mentioned earlier relay chatter is normal when starting but if it continues during driving (as mine did)it ended up being stuck/hung-up
trunk release button above license plate. Chattering caused by switch
making contact and security system (relay would chatter behind radio)
pull out switch/clean and try again..in my case problem solved
worth a shot takes 10 minutes
good luck
65GGvert 06-09-2017 09:11 AM
good luck
That was 7 years ago. I sold the car 6 years ago.
Boomer111 06-09-2017 09:38 AM
Or like myself just do not hear it!
Jerry0 06-09-2017 10:33 AM
sorry
didnt realize old post why was it on forum dated yesterday ?????
was just trying to be helpful
robertmc1958@gmail.c 06-09-2017 10:48 AM
Probably what you are hearing is the RCDLR module. It's mounted just above the radio head. It's completely normal, just ignore it.
