fog lamp bulbs c5
Hi all, I know I have seen the part number for higher watt fog lamp bulbs for a c5 on the forum but I can not find it again. Can anyone tell me the watt size and the part number? thanks in advance
Stock is the 899 (37.5 watt) bulb. I upgraded to 885's (50 watt) with lots of improvement. A simple and safe upgrade.
BUT....most importantly, re-aim your fogs. They are set from the factory WAY too low. Do a search, I think there is an exact number of turns to get you in the ballpark. Good Luck |
fog light bulbs
thats exactly what I was looking for, thanks again
Originally Posted by ALLEGRO
(Post 1572656013)
If you use 885s and reain the lights higher you almost don't need headlights
Replaced my fogs with 885s about 5 years ago. Reaim the fogs by parking say 15 - 20 feet from a white garage door or something like that. Use the low beam height to set the fog light height. Can only go up and down with a Torx wrench but thats OK. The 855s are 50 watts and are almost as bright as the headlights. Can turn on the parking lights and the fogs and not use the headlights unless its really dark.
BIGHANK |
You can run HID's in them...
Who makes HID's for them?
Originally Posted by bighank
(Post 1572660949)
BIGHANK Don't ask............ Plasticman |
fog lamp bulbs
thanks a lot, you guys are awesome on this forum, i am always pleasantly surprised by all the great info given, and they come from all over the country. tom g.
I agree go on fleebay and get the HID upgrade its well worth it.
No Melting after 5 years when should I expect this to happem?
Originally Posted by Plasticman
(Post 1572680657)
Just beware that if the fog bulbs contact the black plastic surround (when adjusting them "up"), the plastic will melt (can see the plastic smoke and melt at night).
Don't ask............ Plasticman :thumbs::flag:BIGHANK |
(Post 1572712069)
Have had the 885s in for 5 years and always run them with the low beams. Have not seen any problems.
:thumbs::flag:BIGHANK If you are looking for them to melt the plastic, then just raise them up further!:D Plasticman |
Originally Posted by Van5150
(Post 1572680435)
100% Plug n Play :cheers: |
I guess not using them as airplane searchlights does the trick
(Post 1572713399)
Please read what I said................ In other words: If you adjust them too far up, and they contact the plastic surround, it will melt the plastic.
If you are looking for them to melt the plastic, then just raise them up further!:D Plasticman Incidentally I used the 889s or 892s from my C5 on my Pontiac Montana which had even lower wattage bulbs but with the same configuration. Got more brightness there too. BIGHANK |
How hard is it to swap the bulbs?
Not hard at all just time consuming
Originally Posted by Slider-01
(Post 1572761135)
Have fun. :flag::thumbs: BIGHANK |
4 Attachment(s)
(Post 1572761135)
Document ID# 780025 2002 Chevrolet Corvette ________________________________________ Fog Lamp Bulb Replacement - Front Removal Procedure 1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information. 2. Remove the front fascia lower close out panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers. Attachment 48180135 3. Release the brake caliper cooling duct from the front fascia and position the duct aside. Attachment 48180136 4. Disconnect the front fog lamp electrical connector from the fog lamp bulb/socket. Attachment 48180137 Caution Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury: o Turn off the lamp switch and allow the bulb to cool before changing the bulb. o Leave the lamp switch OFF until the bulb change is complete. o Always wear eye protection when changing a halogen bulb. o Handle the bulb only by its base. Avoid touching the glass. o Keep dirt and moisture off the bulb. o Properly dispose of the used bulb. o Keep halogen bulbs out of the reach of children. 5. Remove the fog lamp bulb/socket from the fog lamp. 6. Rotate the fog lamp bulb/socket counter-clockwise to release it from fog lamp. Attachment 48180138 Installation Procedure 1. Install the fog lamp bulb/socket to the fog lamp. 2. Rotate the fog lamp bulb/socket clockwise to secure it to the fog lamp. 3. Connect the front fog lamp electrical connector to the fog lamp bulb/socket. 4. Position the brake caliper cooling duct to the front fascia, and press to secure. 5. Install the front fascia lower close out panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers. 6. Lower the vehicle. 7. Check and adjust fog lamp aim as necessary. Refer to Fog Lamp Aiming Procedure |
Done, piece of cake!
Question I have a 2000 C5 don't have fog lights does any one know if the wiring is there just in case you might want to install fog lights
