Originally Posted by Mike Ward
(Post 1572742499)
And still not be able to drive your car. :willy:
But bending over, gives you no chance. I've fought cops in court twice, and won once. The difference between me and someone who would have bent over, about $360. Be afraid of cops and take it up the ass all you want. I'll continue to stand up for my rights. :flag: |
Somebody had a bad bowl of cornflakes this morning :rofl:
Actually I could have asked the cop if I was under arrest and if he said no then I get in my car and drive off. This particular cop would have placed me under arrest for something stupid you can kinda tell these sorts of things sometimes. Then my car would have been towed and probably got allot more than what I got :cheers: |
Originally Posted by MotorHead
(Post 1572743960)
Actually I could have asked the cop if I was under arrest and if he said no then I get in my car and drive off. This particular cop would have placed me under arrest for something stupid you can kinda tell these sorts of things sometimes. Then my car would have been towed and probably got allot more than what I got :cheers: Thanks again for the Demon tuning advice btw. I ended up with 28 HSABs, Lars and a few others scared me away from going smaller. But I wish I had gone with 26s like you. I can only jet it down to 12.5:1 under boost, but I wanted it closer to 11.8. Now I need to upgrade to an Aeromotive 1000, I'm running out of fuel with the boost referenced mechanical pump. |
U could turn the tubes to flow downstream also.
Originally Posted by eastltd
(Post 1572692395)
Has anyone here tried to install a set of injector tubes on their headers?
I see the vendors have BB units for $180. The system looks expensive to put together. If anyone has priced it all out, please post the details. From what I read in this post it looks like we should start pricing out the system and putting it on like Vettebuyer did. At least it would look legal and you could talk your way out of a ticket:thumbs: Who knows, the mod motors might look good with the system on them too. Pics welcome!:cheers: Something to reduce the restriction and maybe reduce a little exh reversion also would be to bend the injection pipes away from the cyl head exh runner - flowing downstream. Maybe produce a tiny bit of flow enhancement too but the air flow from that small pump is almost insignificant compared to what comes out the cyl head (yes i am guess at this:rolleyes:). I had wanted to do this to my headers but CA changed their smog laws and my '74 became exempt. Woopy, no AIR pump required.:hurray: Just an idea for those that have to run'm, cardo0:conehead |
My 72 has the charcoal evap canister, air pump and pcv!
cardo0- I'm betting if you read the CA law on emissions yours will be the same as mine, you don't need to get tested but the stuff still has to be there and operational, could be wrong though :cheers:
(Post 1572747234)
(Post 1572690168)
Mine is/was an 4 speed L48. They did not mention the smog pump to me, :thumbs:
And we do have a mobile emissions test vehicle around here. They sniff you and if you are really dirty, they can order a complete compliance inspection and tuning to get you close to what the factory levels were, so I wouldn't punch out the cats. They look for stuff like that on "sports cars". |
Something we put together a while back, Corvette specific:
Here is a listing of Vettes that did use the A.I.R. system: A.I.R. use on Corvettes: 1966-California-delivered Corvettes, except for the L-72, 1967- All California delivered Corvettes 1968/1969-All Corvettes had the system installed regardless of engine, transmission, or where delivered. 1970-LT1 Corvette (others used the CCS or Controlled Combustion System for emissions control) 1971-LT1 and LS6 1972-All Corvettes except "CKW" and "CKX" coded L-48s. 1973/1975-All Corvettes except 1974 L48 automatic with Federal emissions. 1976- California-certified Corvettes (others went to CCS) 1977-California and "High Altitude" cars 1978/1979 all California cars, "high altitude" and all L-82s used A.I.R. (L-82s were not available in California or "high altitude" areas during these years.) 1980/Current, all Corvettes used A.I.R. donald |
Get a 71 LS5.
A bit lower compression, but no smog pump, just a charcoal canister and a simple CEC system. Tom |
I forgot to mention, our Canadian emission regs were not as strict as the US Federal regs on new cars until about 1990. My '85 Pontiac had 5L, no pump, a non-controlled QJ and it passed the etest (regs for year of make) just fine in '03 when I sold it. :thumbs:
In comparison, the 5L Monte SS had a pump and controlled QJ. |
ok is the vapour canister on the drivers side under the brake booster? what exactly does it do, i dont even think mine is hooked up because i re did my fuel system, so i might just remove it.
Originally Posted by Rich's'78
(Post 1572753429)
I don't want to get into it over what the specs where. I think he just might be saying that if C02 level was X amount in the states ( I don't even know if that is one of the things they measure but anyway) ours might have been higher until 1990. Doesn't California have separate smog specs. I know a whole bunch of stuff I have around my house is illegal or can cause death there :lol:
I still haven't got a definitive answer as to whether my Canadian 1980 L48 came with a smog pump or whatever those ugly looking things are in the front. Do I just try and decode the door sticker or emissions sticker, which is probably long gone, I have a hard time seeing the computer screen ? :lol: |
(Post 1572691509)
It's the price of the air pump I'm looking at I thought they were fairly expensive and also they are pretty ugly looking.
I paid AFR to match the Vic Jr to the 227 heads they did a bang on job, I ain't changing that. All the other stuff like you say is probably pretty easy :cheers: 2. JB Weld an EGR valve to the manifold. It's all very doable, I'd hate to see you give up that beautiful car. http://contentinfo.autozone.com/znet...107/4/image/6/ $86 at autozone |
(Post 1572755228)
Alternatively, what does the AIM say? |
(Post 1572755228)
I still haven't got a definitive answer as to whether my Canadian 1980 L48 came with a smog pump or whatever those ugly looking things are in the front. Do I just try and decode the door sticker or emissions sticker, which is probably long gone, I have a hard time seeing the computer screen ? :lol: Your 80 had an A.I.R. or "smog" pump. There are a lot of C3's that didn't though. My 1972 was a CKX engine code. No AIR, only PCV, Charcoal can and TCS solinoid. |
(Post 1572755228)
:lol: |
(Post 1572757004)
Has your friendly OPP representative given you a shopping list? I'm still amazed that they have someone that knows the exact config of every car ever made to make an accurate on-the-spot assessment, however......
Originally Posted by 63mako
(Post 1572757324)
Check post #89. It looks right.
Your 80 had an A.I.R. or "smog" pump. There are a lot of C3's that didn't though. My 1972 was a CKX engine code. No AIR, only PCV, Charcoal can and TCS solinoid. One thing that bugs me is the cop gave me fine for non original mufflers he said they were too loud. I told him GM doesn't even make the original mufflers for the car any more, didn't bother him. It was night and they are painted black they could very well have been original mufflers he didn't have clue. I asked him if there was a decibel level the car had to meet and he said no, it was basically up to him to decide if the car was too loud :rolleyes: |
