Starting/Charging sytem problem finally FIXED!!
well after 2 months of intermittent problems and changing out my alternator, battery, and even swapping in the stock spark plugs it was finally..
the STARTER :rolleyes: yep, got the first warning couple months ago every few days. Voltage looked low and its been a few years so I though it was a good time to saw the battery. didn't get another warning for a couple weeks so I thought I was good. then it started again, warning light and voltage drop. It would start fine in the morning and voltage looked good then the warning light and voltage dropped as I drove. Swapped in a new alternator, still no good, but I noticed some days were fine and some days I would get the warning warning/drop. I was so desperate I swapped in the stock plugs a couple weeks ago since I heard those might trip the warning light light, still no good, finally today after I drove to work my car would NOT start at all, even though it drove a couple hours earlier, wouldn't even take a jump, Im totally stumped now. Luckily i was working at a garage and one of the guys brought out a jack so he could whack the starter, I didn't never brought that into the equation since the voltage drop symptoms should not have had anything to do with the starter. But no, as soon as he was underneath the battery terminal on the solenoid was COMPLETELY melted! 40K hard miles next to the headers had apparently taken its toll, and it had been intermittently going in and out of contact till it totally fried. worse part is when it goes out the ECU throws a starting/charging system fault and stops you alternator from charging the battery. Why it does this I have no idea except maybe to confuse the hell out of you when you the warning and the voltage drop because you would never think a bad starter would make the voltage drop. :banghead: so anyways, any of you guys that have this prob and are pulling out your hair check under your car. bad news is there's off the shelf replacement solenoid for the C6 right now so you have to replace the whole starter $$$ Good news is the only difference between our solenoid and those off most all LS starters over the last ten years is this one little ignition switch signal lead, switch your to a ring style terminal and you can use any of the old ones. we used one off an old Tahoe and it started right up and No warning lights and 14v all day for the first time in 2 months, REJOICE!!! :D http://img63.imageshack.us/img63/7950/solenoid.png hope this helps some of you guys! |
I would have to think if anyone is running headers, they better think about wrapping vunerable components with some kind of heat shielding?:rolleyes:
ymmv Mike:thumbs: |
Good information Jeremy. Thanks for letting us know about the potential problem. I just installed ARH long tubes and am glad that I paid extra to get them coated now. :cheers:
Originally Posted by mracer
(Post 1572583193)
ymmv Mike:thumbs: |
Great info! Thanks for sharing, especially the trick of using an older solenoid. What kind of headers do you have?
Thanks, Glenn |
Originally Posted by DSteck
(Post 1572584252)
My starter has an insulation blanket. :thumbs:
http://www.cardomain.com/ride/179116/4 Mike:thumbs: |
(Post 1572583193)
ymmv Mike:thumbs: |
Was your car cranking but not starting, clicking but not cranking or was it just dead?
Originally Posted by Invisiguard
(Post 1572585067)
yeah i didnt install the headers myself so I wish I was told about it at the time. Oh well I'll be running some shielding now! ;)
Mracer or others. What heat shielding wrap works best on the starter and where is a good place to purchase it? Thanks
The solenoid is the electrical center or distribution point of the car. Alternator, battery, fuse boxes and of course the starter, all meet there. If that connection loosens up, it'll create a resistive connection which generates heat and melts things. Good find!
How old was the Tahoe ? ? ?
1 Attachment(s)
I tried GMPartshouse.com, Autozone, and NAPA websites, and none had a separate solenoid for an LS series engine, just the starter with solenoid. But backing up to 1999, Napa shows a solenoid for an older 350 V8 that looks like your picture.
Could the solenoid you used be from the pre-LS era ? ? ? Might be nice to have one on the shelf "just in case". |
Not saying this is what happened to the OP, but keep in mind that a lean mixture and/or overly retarded timing can result in headers getting far hotter than normal. My old supercharged LT1 Camaro liked to melt polyurethane engine mounts.
http://para.noid.org/~lj/Boom07/images/meltedpoly.jpg Jeff |
The solenoids can be had from ANY starter alternator repair facility for around $50. There fairly easy to replace but you have to remove the starter to replace them.
Most of those melting/burnt terminal issues are caused by a POOR CONNECTION on the main terminal lugs. When theres a poor connection at the starter solenoid,,it WILL effect the charging system because the alternator doesn't see battery load. The poor connection causes very high resistance in a very HIGH current circuit and that causes Lots of heat and burnt terminals. If you ever see charging system issues "low charging voltages at the battery" you can test that theory by running a temporary 10 ga wire from the BATT terminal on the back of the alternator (under the rubber boot) directly to the POSITIVE battery terminal. If you see good charging voltages, you most likely have a poor connection at the starter lug. I've see this too many time on C5's. Now it starting to effect C6's. :yesnod: I too have headers on my 06 and made my own heat shield for the starter out of a flame retardant foil covered canvas. I sandwiched in some fiberglass industrial batting insulation and secures it to the starter with some stainless steel wire. That baby is cool now!! Heres a picture of A very low mile 04 Coupe solenoid. You can already see the corrosion and discoloration on the terminals: http://img.photobucket.com/albums/v4...7/CIMG0889.jpg I know its not a C6 schematic but you can see how the alternator/ battery/PCM and starter all tie in. I bet ya the C6 is very similar to the C5 schematic: http://img.photobucket.com/albums/v4...ercharging.gif WELL,,,,,,,,,,,I was incorrect. The C6 charging circuit is somewhat different but has a couple similarities. ;) http://img.photobucket.com/albums/v4...ingCircuit.gif BC |
(Post 1572581707)
the STARTER :rolleyes: yep, got the first warning couple months ago every few days. Voltage looked low and its been a few years so I though it was a good time to saw the battery. didn't get another warning for a couple weeks so I thought I was good. then it started again, warning light and voltage drop. It would start fine in the morning and voltage looked good then the warning light and voltage dropped as I drove. Swapped in a new alternator, still no good, but I noticed some days were fine and some days I would get the warning warning/drop. I was so desperate I swapped in the stock plugs a couple weeks ago since I heard those might trip the warning light light, still no good, finally today after I drove to work my car would NOT start at all, even though it drove a couple hours earlier, wouldn't even take a jump, Im totally stumped now. Luckily i was working at a garage and one of the guys brought out a jack so he could whack the starter, I didn't never brought that into the equation since the voltage drop symptoms should not have had anything to do with the starter. But no, as soon as he was underneath the battery terminal on the solenoid was COMPLETELY melted! 40K hard miles next to the headers had apparently taken its toll, and it had been intermittently going in and out of contact till it totally fried. worse part is when it goes out the ECU throws a starting/charging system fault and stops you alternator from charging the battery. Why it does this I have no idea except maybe to confuse the hell out of you when you the warning and the voltage drop because you would never think a bad starter would make the voltage drop. :banghead: so anyways, any of you guys that have this prob and are pulling out your hair check under your car. bad news is there's off the shelf replacement solenoid for the C6 right now so you have to replace the whole starter $$$ Good news is the only difference between our solenoid and those off most all LS starters over the last ten years is this one little ignition switch signal lead, switch your to a ring style terminal and you can use any of the old ones. we used one off an old Tahoe and it started right up and No warning lights and 14v all day for the first time in 2 months, REJOICE!!! :D http://img63.imageshack.us/img63/7950/solenoid.png hope this helps some of you guys! Anyway, I ordered a 1999 Tahoe 5.7liter starter solenoid from my local Advance autoparts. Cut the weatherpack jack off the starter wire and crimped on a circle terminal. Put in the new solenoid and all is good now. This is an excellent tip! Only about $50 for this solenoid when GW wants to sell the entire starter.... Humm.... Several hundred $$$ for a new starter or cut the jack off and crimp on a new connector and purchase a $50 solenoid? Radian www.phflyers.com |
Hey guys... my car has been showing this service charging system light for a while whenever I was in high RPMs (I guess vibrating a connection loose at the solenoid)... and now it finally went nuts and wont even start up. It HAS to be the starter solenoid... to remover the starter... do you have to take off the passenger side cat down pipe? I took out the 2 starter bolts and it will not clear the cat to remove it.
Please let me know what you had to do to get the starter out! Thanks, Bryan |
If your car has an OEM cat/midpipe,,they come down as one unit. Not seperately. Most aftermarket mid pipes also are one unit because they have an X pipe or H pipe.
You migt as well frop the entire exhayust system. Its easy. BC |
Originally Posted by FASTBLUEZ06
(Post 1573471080)
Please let me know what you had to do to get the starter out! Thanks, Bryan Radian |
(Post 1572584252)
Originally Posted by GregC6
(Post 1574187060)
any pics? where did you get one?
