Originally Posted by Tom400CFI
(Post 1572609032)
I've read that on here too. That is a bypass valve and is not the same as a Waste gate. The bypass valve functions MORE like a recirculating BOV on a turbo car and I believe that it is intended to improve efficiency during closed throttle, high RPM situations, and/or the narrow parts of the engine's RPM range where the engines pumping efficiency doesn't keep pace w/the blowers. Incredibly inefficient to operate that way on a regular basis. I don't believe that is the purpose or function of that valve on the ZR1. I said it before and I'll say it again; If that is the valve's function; to bleed off boost on a regular basis, prove it. That is just WAY too inefficient to be an as-designed feature.
I will say HANDS DOWN, that the ZR1 will not "make its 10.5 lbs at any elevation". Our snow cats are only certified to make hp up to 12,000'. Above that, the turbo is maxed out. I highly doubt that the ZR1 has that large a margin built in, and "bleeding it off" all the time at sea level. What a waste of energy that would be. |
How can you tell me that? How have you measured it? I'd guess the factory gauge?
We need more data and tech info on this system. Or maybe I do. |
(Post 1572612378)
And Tom im not trying to argue with you but what point are you trying to make? Im going to say that If a bone stock LT 1 on crappy tires ran a 13.8 I guarantee a ZR1 with a good driver will run high 10s at that track......and while we are on the subject of elevation dont forget the advantage of wind resistance at that level.......I am an avid golfer and know the ball flight laws of elevation and Its huge differences so I think that the aerodynamic effect on a car must be large as well but am not the scientist to test it just the golf ex makes me think about it and why some forced induction cars have records at elevated tracks.
golf example from when I played professional golf: 8 Iron at sea level 155 yards 8 Iron at 1400' 163 yards 8 Iron at 5000' 187 yards |
I wasn't trying to argue or interrupt your great thread. Sorry for that disruption. I was mainly trying to correct what I thought was misinformation. I need more education for this particular 'charger, however.
I LOVE Corvettes, the brand and the model. I'd LOVE to see a ZR1 run high tens here, but I'd bet a LOT of what I could that 10's won't happen for a ZR1, ever, above 3000'. The fastest C6 Z06 that I've ever seen here ran 12.5, driven by a GM engineer. NA again, I know, but...that is WAY off the mark. EDIT: here is another reference point. '05 Caddy CTS-V; Kooks, full exhaust, Maggie, 470 at the rear wheels. I know the driver and he can drive. 13.3 was his best run. |
(Post 1572621827)
Originally Posted by blownlt1&c6z
(Post 1572625413)
So your saying he was a good driver in that car and only able to out run a stock LT1 with a whopping 250 or so RWHP by .5 Im still missing your logic? As I said before if a stock LT1 on bad tires can run in the 13's a ZR1 is going to run 10's with a good driver...How can you not follow that logic...
I'M SAYING: I gave two supercharged examples who are local, one of which I know personally; a '10 Camaro, and the '05 V. Both ran low 13's. That is very in-line with what you see here, at this elevation.
(Post 1572625413)
you are going to have a few days where the DA is very close to 0.
(Post 1572625413)
And further more I have seen plenty of GM engineers that cant drive worth a shi+ so unless it was John Hinresery...
Here's the deal; If you are so confident that a ZR1 will run 10's at RMR, bring it out here. I'll put you up in my house in Park City, give you a bay in my garage for your car, and feed you for your stay. 10's will never happen, stock ZR1 at this elevation. As much as I have a wood for this car....never happen. |
I think you are still missing my point......that 13.8 is all that stock lt1's run here on the east coast......I started with my 95 Brand new in 95 got alot of passes on it bone stock on a good track with good air.....best I ever ran was 13.78 100% stock.....then I started the modifications. So I am asking what makes it possible for you to be able to run the great time in your N/A LT1 but you say the ZR1 wont do it ever? You must have had the perfect day with perfect prep to out run the other stock LT1 times of your track by 1.2 seconds???? So again how are you saying its not possible for it to ever happen with the ZR1?
You were able to do it with the LT1. |
I don't know what to tell you. I "Did it" with my bone stock C6, also, running a 12.89 to everyone else "around heres" 14.00's. The fastest stock or stockish C6 I've ever seen around here was a 13.9x. I beat that by 1.1 seconds and I've beaten every other stock or stockish C6 by 1.2+ seconds. How? Did I somehow get "perfect weather" or "perfect track"? Or perfect this or perfect that? I already told you above, w/my DA that I didn't. And I never will, around here.
I can't really tell you for sure why my numbers w/my LT1 don't jibe, w/what you're saying....but here are a couple possibilities in order of highest likelihood: *LT1's have run faster at sea level than yours did, or than you're claiming. I believe that there are several very low 13 LT1's out there. Before your post, I've never heard anyone say that 13.7 is the best an LT1 can do. http://www.dragtimes.com/Chevrolet-C...slip-1190.html http://forums.corvetteforum.com/1550514822-post2.html *My LT1 is not stock. Maybe it's a "sleeper" with a stoker crank, 1.6 rockers, a cam, and ported stock heads and ported stock intake manifold....but bone stock exhaust, intake, injectors, TB, with a stock-like idle and still gets 25+mpg on the highway. <-possible, but not likely. I told you above; if I took this car there, I think that I could almost tag 12's w/it. It's a good running car, and the launchability and shiftability of it is amazing, compared to the C6. I believe that the point you're making is that my LT1 times here, basically match your LT1 times there...so therefore, "I'm not loosing much to elevation"...which just ain't true. 12.89/111 in my C6, here. Fastest LS2 C6 on the list I believe is 12.21/115. I'm way off that...and why? Elevation. Fastest stock LT1 I believe is ~13.1...and I'm way off that too. *I have run previous cars I've owned, to their lowest number here. *I have done the NHRA corrections for those cars. *I have gone to lower tracks w/those cars, and run the NHRA corrected number. When I was a "Flat lander" (grew up back east/ran at Epping) I doubted the effects of elevation, and was highly skeptical of the "NHRA correction factor". But since then, I've lived it, felt it, seen it, and confirmed it, objectively. |
A quick trip down memory lane.......Mr MOJO's car was ? for really being stock by more than one person on here and you can find in some of his posts about having the mufflers off the car.....but claiming that slowed him down....So why do it?.....I also looked at my old time tickets and checked the DA for that day back in 1995 at Mason dixon drag way.....Back then nobody watched DA to explain cars.....I checked and it showed I ran at +2700 I was on stock crap GSC tires as well so I do believe that the stock LT1's are capable of 13.4 to 13.5 here at sea level with good air. I thought I was running in very good air back then but now I see I wasnt. But back to the ZR1 none of us that are racing these cars believe that we are any were near the bottom yet with my 10.74......I ran that on only my second time to the track with the car.....I believe we are going to see some low 10.6x's on stock tires next year and I think low 10.50s will be run on DR's And I do think you will find that the elevation will hurt the ZR1 less than it hurts the other cars you are speaking of......You should go drive a ZR1 and see how the car is not working very hard at all to do what it is doing......A Z06 Feels like it is maxed out as it reaches redline ever time I drive them where as the ZR1 just feels like its out for a sunday stroll.....Hopefully someday someone that can drive will show up to an elevated track with a ZR1 (not the non driving person that was in the video in this thread) Then we will see what It is capable of.......But for now I am having to pass the time till the snow melts bench racing....
(Post 1572628841)
I think you are still missing my point......that 13.8 is all that stock lt1's run here on the east coast.......
Can't speak for your car, but I can tell you I've seen many stock LT1 cars run much quicker than that on the east coast. :yesnod: For that matter, some stock L98 cars have gone that fast. :thumbs: |
Originally Posted by TA
(Post 1572631374)
People questioned Mr. Mojo? It's Ironic that you are also questioning him, in the same thread that you're posting a claim of your own. Everyone has respected your claim. Why can't you? Some more "schooling" for you about stock LT1's...
http://forums.corvetteforum.com/1558785602-post13.html http://forums.corvetteforum.com/c4-t...ile-times.html I say it again; My car would run damn near 12's there. Your car might run mid 11's here. Regardless of how "ZR1 feels like its out for a Sunday stroll", there is this annying thing called science, that trumps "feels like". No ZR1 will ever run 10's at or near my elevation. |
(Post 1572633344)
Geeze dude...relax. :)
(Post 1572636230)
The only reason I ? him at all was that in his own posts he talks about removing the mufflers and some other tricks for free horsepower....that to me is not a true stock car.....and he was not on stock GSC tires either...Did you even read the threads you sent me????? these are all modded cars! close to stock but not stock....
(Post 1572636230)
I ran 12.70 in my 95 with just autoX tires, Exhaust, Ram Air set up and the free mods like coolant line bypass....My ZR1 is 100% as delievered from GM!
(Post 1572636230)
Anyway if your track is so bad drive to another track.....Thats what I do! there are alot of tracks much closer to me than MIR....I just choose to drive the 3.5 hours to race at a great track!
*5 hours to run at 2200' elevation with a 4000' DA at Vegas. *Or 8 hours to run at Bandimire which is higher than our track. *Or 10+ hours for a track in CA. Sure hope I don't break anything though! You can see that it's not all that practical or even managable for me to just "drive to another track". Although I HAVE driven the 5 hours to Vegas and run there...which is where I have seen first hand, the effects of elevation....of course not to mention when I originally moved from Mass to Utah. Don't forget after all this "fussing" about my LT1 numbers...there is my C6 numbers as well. |
(Post 1572633344)
All places in our great country have their ups and downs......I am jealous as hell of your skiing! I guess we are back to the original ? how this all got started and I stand by what I say......Altitude does not affect a supercharged car as bad as a NA car! |
(Post 1572638657)
Might want to rephrase that! Im pretty sure the LPE bolt on car would have no problem running 10's at your track.....Being it ran 9.8's here.
(Post 1572638657)
(Post 1572638657)
I hate having to run at 5600 feet above sea level with a DA of 8k plus. The car feels like a geo metro
(Post 1572638657)
Originally Posted by Racer44
(Post 1572645537)
Maybe not as bad, but it does big time. My S/C Z06 could only pull 5lbs here in Calgary (aprox 3500ft), down at 750 feet it pulled the 7 lbs it was built to do. No o2 is no 02, plain and simple, unless you can compensate by turning the vanes quicker etc with pulley changes etc to get more of that bad air in.
