Originally Posted by tt 383
(Post 1572400521)
The magazine article proves that if you have money they will print what ever you want them too no matter how incomplete or shallow the testing.
It wasn't an engineering study, but I thought it was a pretty decent set of test scenarios. |
I can't believe how stuck in the 70's a few of you guys are.
In Europe people would laugh themselves stupid at the idea that a carb is better than EFI. The only race cars here that still use carbs run in controlled historic racing categories, even the lowest of amateur racers go for EFI. I do accept that for many people a $300 carb is much better value than a $1500 EFI system but to say a carb can out perform an EFI setup is like suggesting an abacus can be as fast as a computer. |
Originally Posted by Golden
(Post 1572400859)
Carbs still sometimes show slightly higher peak HP on the dyno. If this is the definition of "perfomance" for someone, then they see things differently. Factor in throttle response, driveability, fuel economy AND peak power and EFI clearly wins. Price/Performance is also a tough call right now. Carbs is cheap, and if well-tuned pretty decent :) Finally, the very latest generation of mass airflow-type EFI systems is a total game-changer. I've worked with some of the older stuff from Edelbrock, Holley and GMPP...and although it worked, it wasn't great for power or economy - and it was persnickety to set up and tune. So, the times they are a changin' and I do think people need to look at what's happening right now and build some awareness of the latest generation of this stuff... |
(Post 1572400859)
In Europe people would laugh themselves stupid at the idea that a carb is better than EFI. .. |
Originally Posted by gerry72
(Post 1572401197)
it's quite clear no one is pronouncing the superiority of a carburetor as a fuel delivery device.
Otherwise, :iagree: with your comments. |
I didn't read the article, but if the EFI doesn't include at least a knock sensor, wide band oxygen sensor, the ability to learn/be programmed, and some learning time, then the comparison is a wash.
The EFI should also be some sort of port injection with a completely different intake manifold design. Most of what we consider a 'good' intake is basically just compensating for the limitations of a carburator. |
(Post 1572401197)
No one is saying that. Language differences aside, it's quite clear no one is pronouncing the superiority of a carburetor as a fuel delivery device. It's quite the opposite. The only point of the thread was a carburetor "can" make more peak power than EFI, but we don't drive our cars full-throttle all the time nor do we all have perfectly tuned carburetors so that minor difference becomes irrelevant and nothing more than a topic to discuss. Let us know how all of Europe feels about that.
WOT is possible the easiest fuelling area to set up, it's the transitional set up on both carbs and EFI that's tough. A carb is never going to be a match for EFI, as the fuel air mix in a carb is governed by the ever changing pressures and airflows within the intake. The fact that an EFI system sprays a perfect mist in the manifold, regardless of manifold pressure, reversion waves, cylinder robbing and all the other things that effect venturi pressure, make it head and shoulders above a carb. I think too many people still see EFI as the same half cocked rubbish GM put on in the 80's. |
Originally Posted by not a '76
(Post 1572401664)
(Post 1572401880)
:iagree: So true.
The test in question uses a 750 carb for a 420 hp engine, wouldnt a 650 be a much better carb for said engine?
Golden, since there are so many great kits in the UK that work so much better than carbs maybe you can post a few links where back to back test were done and the affordable/ easy to tune EFI makes more peak? Seems to me on the many forums I visit that a few of the builders experience a common scenario where EFI is to be used and the tech achieves less in two days dyno time than by the builder bolting on a carb and crap design intake to make more power in a few pulls. EMC this year had very bad air, the test is average power over 4000rpm pull. These are 2 elements that mount in the EFI camps favor. A good setup carb will get good mpg, it will accommodate big changes in weather, and in WOT it will make more power than a cheap/production EFI system. How many high end EFI systems in road course or timed events (ALMS, CART,F1,ROLEX SERIES) actually run the processor/sensors instead of a map that somebody programmed? Seems redundant to me to pay so much for something just to program how its gonna run with multiple fuel maps. EFI biggest advantage is that its a pressurized system. No matter how you look at it a carb works off of real time, not so with EFI........ Troy Patterson put it this way on speedtalk, look at a leaf blowing in the wind and how it responds(like a carb) and then try to use sensors and controllers to make it move the same way in the same time frame(like EFI), or something like that. |
:iagree: 100% and the big problem is not many know how to setup a carb correctly ( and I am not saying I do either ). When done so it performs much better than many think :cheers:
(Post 1572401872)
I'll try and answer your questions.
(Post 1572403096)
(Post 1572403096)
(Post 1572403096)
(Post 1572403096)
(Post 1572403096)
A carb relies on a vacuum 'signal' at the venturi to try and match a flow of fuel to what it perceives as a certain amount of air going in. This airflow is constantly disturbed by factors created by the engine, reversion pulses, valve overlap, cylinder robbing, inconstant manifold temperature, the list goes on and on. EFI ignores all of those factors and delivers the correct amount fuel regardless of airflow disturbances in the manifold. An EFI system can calculate how much fuel an engine requires thousands of times a second, more than fast enough to keep up with changes in load and revs. |
Golden, As I read the posts on this thread, it is ridiculous to categorize the US as a country, group, or culture of people who think an old analog fuel control system (carburetor) can equal or come anywhere close to the capability of today's highly sophisticated digital control systems (todays EFI systems). All I can do is throw up my hands and say, please guys, talk to people who really know wtf they are talking about. We are designing digital autopilots that guide a 2000 lb brick (bomb) to within a meter of its target. We don't do that with an analog/mechanical control system. I would be laughed out the door if I even suggested it. Trying to debate this issue with people who have never been educated in control theory is like Don Quixote jousting the windmill. Futile, It has everything to do with knowledge. Don't take me wrong, we all take a position based on our experience and what we know but smart people defer to experts in the field. Today's experts wouldn't give a carburetor a nano second of thought as an option for optimizing an engine for performance. Peak HP or otherwise.
Bullshark |
So in your world where for 20 years carbs don't get used, you determine that efi must be superior? Yet in that admission, you have no real real proof in the form of data because no one uses them? Please maybe you can enlighten everyone as to what exactly goes on at WOT in an EFI system? What part of the system do closed loop sensors control at that point? Some systems the MAP doesn't even read, relies purely on throttle position. I still dont understand how a sensor reading what goes on in the intake is doing anything different than a carb? It still reads the same air reversions and cylinder robbing, but in past tense it makes its adjustments. Venturi does nothing more than magnify the signal at the booster, to get an accurate reading. You make it sound like a carb has no atmospheric compensation in it at all, thats just not true. Troy Patterson clearly hasn't accomplished with carbs what you have with efi, but thats another thread in itself.....
The real issue with 'proper' good quality MPFI is the cost of it - especially here in the UK (if you are injecting USA engines) a fully mapped individual runner Kinsler system would cost me more than my recent BBC engine build-up. Unless you are driving many thousands of miles per year (and not too many of us doing that in our 'fun' car just now with the current economic climate) then the mpg improvements just don't pay for themselves - EVER. Performance benefits - questionable again.
I was a big Q-jet fan. Read everything by Lars and Ruggles. I had Brad Urban modify my Q-jet. Then I bolted on a very basic Holley Throttle Body Injection. The driveability and throttle response is phenomenal and the gas mileage ain't bad. I'll never go back to carbs.
http://i52.photobucket.com/albums/g3...orvette187.jpg Bee Jay |
Originally Posted by Bullshark
(Post 1572405064)
Bullshark
(Post 1572403244)
Reversion waves and cylinder robbing are a manifold design problem not a carb issue. If you have a poorly designed manifold Carb or EFI it will not work properly anyway..... I would assume why race pieces with no package requirement use either a Tunnel Ram, or IR setup.
(Post 1572405110)
(Post 1572405110)
http://www.fordmuscle.com/archives/2...NarrowBand.gifhttp://www.fordmuscle.com/archives/2...phWideBand.gif Whether a system runs open or closed loop, you seem to think that in open loop it becomes a static mechanical system. It's only lambda control that's not used. Fuelling is still corrected for manifold pressure (load), intake air temperature and engine temperature. Additionally on some systems/engines fuelling and ignition are corrected for knock and in some cases with sequential injector firing and multiple lambda sensors, individually corrected per bank/cylinder.
(Post 1572405110)
(Post 1572405110)
(Post 1572405110)
I'm sure Mr Patterson knows his stuff and is an excellent carb builder, but to me there are only two reasons to keep a carburettor. Originality and cost, if your carb starts to cost the same as EFI you're throwing money down the drain. |
Golden. good job. :thumbs: You get the Don Quixote award for your persistence. BTW, Carbs can't tune fuel to the individual cylinder like todays MPEFI. That alone offers a degree of optimization at WOT over TBI / Carb. It's not a large number but it is real and measurable. I have seen the evidence on an engine dyno. :beatdeadhorse: :leaving:
Not to go OT, but this is a great book for understanding EFI on a broad level as well as specific to the Corvette.
http://www.amazon.com/Corvette-Injec...0636445&sr=8-1 |
