Long Tube Headers - Do you have a "ticking" sound? Or other annoying sounds?
I'm still on the fence with buying Long Tubes. I was looking at the LG Streets. I love the idea of the great sound and performance but I can't stand annoying sounds or rattles at idle. I've heard that because of their thin walls headers will give you a ticking or sewing machine sound.
Do any of you guys have this sound or any other unwanted noise/vibrations from your LT Headers? How loud is it and can it be heard from the cabin? Only at idle or at speed? Thanks guys |
Yes they are noisier. Sounds like a sewing machine.
Can't have your cake and eat it too. :) Only hear it at idle, from outside the car. It doesn't sound like something's wrong though. |
Originally Posted by Stevo92z28
(Post 1572235942)
If it was inside the car and i could hear it all the time and it got louder as the RPM's went up it would be a problem! |
(Post 1572235942)
Only hear it at idle, from outside the car. It doesn't sound like something's wrong though. Cant hear anything like that in the cabin though. Nothin but pure aural bliss! :cheers: |
OK I can deal with that. Any other problems or vibrations or anything?
Ticking/Sewing Machine Noise
I only hear the ticking noise with the stock rocker arms. Yella terra rocker arms quieted the noise...until one of them broke.
Originally Posted by muelledc
(Post 1572237435)
Save your money, you sound like the kind of guy that should
stay completely STOCK. |
I have the LG LT'S PRO's and there is some ticking at idle (engine firing exhaust in the header noise) yes because of the thin walls,but once you thottle up you can not hear it any more.The noise nothing compared to the gain in power. good luck:cheers:
So i had to check this out, inside the car I don't hear it, but I do hear valvetrain. Even stock I heard valvetrain noise. I had to pop the hood an tune out exhaust at the back, valvetrain to get a hint of the exhaust pulse noise. but its not something I noticed before personally.....
You can also get a ticking, whistling sort of sound if the joint where the headers meet the x pipe isn't tight.
Yep,mine have the ticking at idle too. Just something you learn to live with.
Also,after reading your post again. You should stay stock for sure. |
Originally Posted by road pilot
(Post 1572237684)
Well I'm already far from stock. Like I said I have no problem with some sounds outside the car only at idle I just don't like annoying noises/rattles in the cabin while driving. Sounds like LT Headers will work for me. I'll let you guys know how it runs when they are installed. :)
