stand alone control for a 4l60e?
After going through the PIA of changing wgts and springs on my 700r4 (see c4 tech for my post on it!) -when this tranny blows I'm really considering an "E" tranny; but I don't want to change my ecm and harness etc etc.... so I was wondering if anyone knows of a stand alone control module to run it that is still programmable? Or-does the "E" require specific inputs from tps etc...thinking... could I throw a pcm in there-flash what I want it to shift at and then splice in the required inputs from my existing tps etc????? Let it "set" codes for all else-don't care-but would it still run the tranny correctly? Anyone done it? It sure would beat yankin' that &*^%$*&# gov. too many times! |
Re: stand alone control for a 4l60e? (drive it)
I'm interested in the answer to this also. I hope someone has the answer. :yesnod:
Yes there are standalone controls for the 4L60e and 4L80e transmissions. TCI and others have them, check this page out http://www.tciauto.com/electronics/index.htm
Re: stand alone control for a 4l60e? (Smokehouse69)
Yes there are standalone controls for the 4L60e and 4L80e transmissions. TCI and others have them, check this page out http://www.tciauto.com/electronics/index.htm |
How would one go about building a set of controls to manually control upshifts and downshifts? I want to find out how to make a paddle shifter for this tranny so that it would opperate as an auto unless you flipped a switch or something and could then use the new controls to select the current gear.
I don't know anything about the programming of these things yet though... Does this sound like something that could be done? :confused: Any ideas of how to accomplish this? |
In the 2001 copy of GM performance parts, page 169 they have a kit to install the E transmission in other cars. Part no. 24502513
Re: stand alone control for a 4l60e? (Red 86 4+3)
In the 2001 copy of GM performance parts, page 169 they have a kit to install the E transmission in other cars. Part no. 24502513 BTW - The 12497316 is also on major backorder with GM right now so I wonder if TCI has 'em on backorder too??? |
Re: stand alone control for a 4l60e? (18carfan)
In the 2001 copy of GM performance parts, page 169 they have a kit to install the E transmission in other cars. Part no. 24502513 Actually, the 24502513 is just for controlling TC lock on a regular 4L60 or 700R4. It won't control the electronic functions of the 4L60E or 4L80E. Gm does offer a kit that does. It is P/N 12497316 but it is the TCI controller mentioned above with a GM sticker on it. -Jeff Im sorry, the part no. I ment to post was 12497316. Jeff will this one work on using a E transmission in a non e car? BTW - The 12497316 is also on major backorder with GM right now so I wonder if TCI has 'em on backorder too??? |
[QUOTE]
Im sorry, the part no. I ment to post was 12497316. Jeff will this one work on using a E transmission in a non e car? QUOTE] Yes, exactly. It is a very user programmable unit. Comes with a cable you hook up to a PC or laptop and make changes to the parameters for upshift points, downshift points, shift harshness, etc. I have a copy of the intructions that come with it. If anybody is interested in having it faxed I could do that or maybe even scan it to e-mail or something. -Jeff |
OK, so the stand alone will control a 4l60E, now another thought....the 4l80e is even stronger, right? Would a 4l80e fit in there?
Would a 4l80e fit in there? http://forums.corvetteforum.com/zerothread?id=246034 |
I have talked with http://www.bowtieoverdrives.com/
Wonderful people to work with. They sell a Compushift unit to control the elec trannys. They also sold me a new cross member for a 4L80E in a 1981. It's a tight fit, but it can be done without cutting fiberglass. |
Re: stand alone control for a 4l60e? (dsagers)
I have talked with http://www.bowtieoverdrives.com/ Wonderful people to work with. They sell a Compushift unit to control the elec trannys. They also sold me a new cross member for a 4L80E in a 1981. It's a tight fit, but it can be done without cutting fiberglass. |
OK, I understand your rant, and hope you find a solution to your tranny problems soon. It will likely mean a different tranny that the 700r4. Too many built cars are eating them for lunch.
As for the subject, the tranny controllers Bowtieoverdrivers sell are made by Compuserve, a separate company. Based on the info from the few people who have plunged in and paid the price for these controllers, they are fantastic, but at $1500, they better be magic. The GM units referenced above aren't cheap either, something like $1000, and these do not offer anywhere as many features as the Compuserve. I decided to go with a 4L80E because of the strength and the overdrive. On several occasions I almost bought 700r4 units, but became cautious when the sellers said they were going to a TH400 or 4L80E. Seems too many guys are busting these trannys. So I could either pay the price of admission up front or just plan fixing a 700r4 every year. Since laying under a car pulling a tranny ranks right up there with changing diapers, I'll buy the best I can up front and pay a little more. |
I have completed a 4L80E conversion in my C4. I fabricated an adapter utilizing the factory torque channel with minor shortening and drilling...I am actually selling the torque tubes and brackets for 4L80E ...$500.00 for the conversion hardware ready to bolt on.
