Spark Plug Torque Specs are 11 foot pounds
I was perusing thru Volume 2 of my GM Service Manuals (# 6-1031) and confirmed the proper torque for installing new spark plugs 11 Lb. Ft.
Guys that ain't much - for me it's finger tight. Just thoughts I'd pass this along - hopefully to alert overzealous backyard mechanics. The heads are aluminum. |
I'm a long time Saab mechanic and have been dealing with aluminum heads for over 30 years.
Yes, the correct torque doesn't feel like enough. Until you develop a feel you should use a torque wrench - and I believe in a small dap of well placed anti-sieze compound.... |
^ +1, well said.
Thanks for the info, OP! |
This place is a wealth of info......everybody is supposed to know that, right? Probably not! Good post, thanks.......:thumbs:
Originally Posted by NatB
(Post 1571919833)
Originally Posted by ZeeOSix
(Post 1571939651)
I'll give you a million dollars if you can torque a spark plug to 11 ft-lbs with your fingers. :rofl: A human might be lucky to reach 1 ft-lb by hand.
I always use a torque wrench and some anti-seize when working with spark plugs. :thumbs: You must be kidding - I can easily turn 11 ft lb. with my fingers/hand. Are you really serious ? This is very low torque - and have been told by guys with Ford GT 40's and Ferraris to only tighten spark plugs finger tight ( albeit with a strong twist). I have followed this advice for many years and on several cars. I prefer to use torque wrenches and agree with you on that - But most torque wrenches aren't accurate to this low level. Can you recommend a good torque wrench for this ? |
http://www.matcotools.com/Catalog/to...ype=T&cat=2108
I like the fixed head stuff for things not in a car, but if I remember right, their 5-75ft/lb (TRB75F) should be enough for almost anything engine related. Only problem is that they arent real cheap... :-( |
(Post 1571939837)
(Post 1571939837)
Yeah, I'm serious. 11 ft-lbs is impossible to do by hand (without tools, and just your fingers) ... but is "relatively low" torque to do with tools.
(Post 1571939837)
GOod info.
regardless of the car, on an aluminum head I tq plugs to 18# and always use anti-seeze. NEver had a problem :cheers: If you want to get fancy you can always index them... |
Sorry- I guess my reference to "finger tight" may have been taken a bit too literally. While I do have an extremely strong grip:cheers:, I was really trying to stress not to go nuts in using a long handled racket. I actually use a racket and grab the end that's over the socket - so as not to amplify the leverage. That is what I mean't by finger tight - Eleven foot pounds is snug and not tight.
As for my question on torque wrenches- I say it is not easy to find an accurate torque wrench that measures down to 11 foot pound ( at least in most DIY home garages). Yes you can buy one - but again, the accuracy is not great unless you spend a lot of money. I have done this enough time to have a good feel for 11 foot pounds - it is very little. Anyhow- hope my original post helped . |
(Post 1571945647)
(Post 1571945647)
Just use inch-pounds, guys. Geez, 11 ft. lbs. is 132 inch lbs. Get a 3/8" inch-pound torque wrench and do the math. :thumbs:
Harbor freight should have what you need !!
For that pesky Plug #7 - Do you know whether a 1/4" Spark Plug Socket is made and where to buy ? That tight spot might be easier with a short swivel 1/4" racket and socket.
I looked at several places this past wek-end and could ony fined 38" and 1/2" drive sockets. I could always squeeze a 1/4" to 3/8" adapter on the racket. |
(Post 1571953157)
