Carpet Glue
For anyone who has had to work on a piece of trim, to which carpet is glued down on, I'm sure you will agree that removing the old glue from the trim is quite a task. Well, now that that is done, I will need to replace that glue so as to reattach the carpet. Does anyone know what kind of glue that is?
3M Carpet Adhesive
AKA: Carpet Glue |
Originally Posted by PLRX
(Post 1571206908)
3M Carpet Adhesive
AKA: Carpet Glue |
The
Originally Posted by dsmithh
(Post 1571206070)
I use 3M Super 77 multi-purpose adhesive which is very good. It's a lot stronger than the regular 3M adhesive.
I used the 3M adhesive in the green can. I believe it was High Strength 90. I sprayed both the carpet backing and the plastic part the carpet would mate to. Then I let them set up a few minutes until they got tacky and ten installed the carpet piece. Make sure you have things aligned cause it will be very hard to get them back apart.
Wouldn't that stuff make a mess if you are spraying it in the car? The one place I know I'll need to reglue is the tranny tunnel carpet that glues down to the floorboard carpet. what else gets glue? I'll be pulling the carpet to install sound deadner, and to steam clean the carpet.
I would be putting the glue on after the carpet is installed, so I think using a spray would mist glue all over the place. |
I used the 3m hi strength 90 also. It is manageable to spray in the car. Just take your time.Make sure you glue both sides wait a few minutes then attach. The trans tunnel and knee bolsters are the parts that need to be glued
Originally Posted by jon0108
(Post 1571238550)
I know the front tranny tunnel carpet gets glued to the floorboard carpet. But does the carpet beside the seat get glued to the console? Or is all of that just bolted or pressed into place? |
your correct on the knee boolsters. It is also on the passenger side in the same location. And I'm pretty sure that the carpet on the side of the seat gets glued in also.
On my 85, the carpet on the floor wasn't glued anywhere.
Yeah, I'm gonna pull the carpet as I've got a moldy smell from water running under the floorboard carpet. I'm sure there probably is mold/smell in the floorboard carpet fibers, but most of it is probably underneath. I guess using regular mold killer stuff from Lowes would work fine to clean up the floorboards? What do you guys use to kill mold in carpet fibers that is safe for the carpet?
Originally Posted by joshwilson3
(Post 1571236737)
I would be putting the glue on after the carpet is installed, so I think using a spray would mist glue all over the place. That being said,do take care to mask off areas you dont want to get glue on if your aim is wrong.When you get a can of spray glue,use a piece of cardboard outside of the car and practice on it.You will see how it sprays where you aim it. That aside,when I did the tranny tunnel carpets i took the panels off and set them on a work bench,sprayed the back of the carpet and put the carpet on the panels.This was on an 86 so it may be different. Then I added some books to provide weight to push down on the capet to the panels,and let it sit all night.Next morning they were dried perfect.Installed them into the car and they never lifted from the bottom.Didnt have to glue them down to the bottom carpet. If you must glue them to the bottom carpet,get some painters masking tape,the 2 inch kind and put it below to mask off and spray the bottom of the trans tunnel carpet and then stick it down.Put some kind of weights on there so they dont lift and let dry a few hours. :cheers: |
(Post 1571257170)
So, which 3M spray adhesive is the best to use? I've read on the net not to use a spray adhesive for carpet as it doesn't hold up, but to use a brushable carpet adhesive. Some of the carpet that will be glue is virtical, so I wouldn't want the carpet to start peeling off.
I've looked and some of the tranny tunnel carpet is pulling off the console plastic piece. So, since it is already out. I'm gonna finish pulling it off, clean it up and reglue it. Is there some way for you to tell how to align the carpet back up to the trim piece when you glue it? And what do you use to clean up the pieces that you plan to glue? |
(Post 1571206070)
No smoking in there after this or drinks/food:nono:-just my opinion. |
(Post 1571951838)
(Post 1571953089)
WHen i did my 86 i used 3m HI Strenght 90. i think thats the one for permanent installations. Spray the tranny tunnel then the carpet pieces, wait a minute then adhere. 2 years later and still good.
Though, I've still looking into replacing the factory Jute that is in the floorboard and tranny tunnel. I've heard things of Reflectix. Would that alone be fine in a C4? I called a local upholstery shop and they have some carpet adhesive in a 5 gallon bucket. And they said they could sell me some out of it. Though they say they use a spray gun, but they said I could brush it on. They did say that 3M spray can adhesive is garbage. |
I don't think
(Post 1571958504)
Are you talking about spray adhesive right on the tranny tunnel of the car? Cause adhesive doesn't go there.
Originally Posted by josephf31
(Post 1571966706)
so (the 3M stuff being garbage); maybe from a commercial/shop point of view, yeah, but I been using this stuff for years for carpet, headliner, etc. and it always works well -- sticky as heck and holds up just fine.
Either way, I like the idea of brushing it on vs. trying to spray it and keep from making a mess. The carpet is coming off on the side console plate. So, I plan on pull half of it back, apply glue. Let it set, then pull the other half back and apply the glue. That way, I don't have to worry about trying to get the carpet aligned up. I also need to reglue some of the carpet on one of the door sills. |
