changing the turn signal?
Anyone tell me how hard this is to do? I have a 05 bought it used didnt come with a manual and tried a search couldnt find what i need :(
You can download the 05 OM by going to the FAQ C6 "sticky" at the top of the forum home page and looking under Owners Manuals. In there your will find what you are looking for. good luck!
From the owners manual:
To replace a high-beam or front parking/turn signal/DRL bulb, do the following: 1. Turn the wheel to allow access to the wheel well. 2. Access the high-beam or front parking/turn signal bulbs by removing the access panel. To do this, remove the three outer fasteners and flip back the cover. 3. Remove the outer cover to expose the high-beam headlamp bulb socket once the access cover has been removed. 4. Remove the headlamp bulb by releasing the outer tabs from the socket. 5. Remove the front parking/turn signal bulb by turning the bulb socket counterclockwise. 6. Replace the high-beam headlamp bulb with a new bulb and reattach to the bulb socket. Replace the front parking/turn signal bulb by turning the bulb socket clockwise. 7. Reverse the Steps 2 through 4 to reinstall. |
Here is what it looks like with a few of the fastener pins removed and the cover "flipped back":
http://i74.photobucket.com/albums/i2...ightAccess.jpg |
Thanx guys:thumbs:
Originally Posted by mikez51c6
(Post 1570829924)
Anyone tell me how hard this is to do? I have a 05 bought it used didnt come with a manual and tried a search couldnt find what i need :( I suspect that's what you meant. |
Yep thats what I did:thumbs: not as bad as i thought would have been easier with tire off but its done now was hard to sleep last night thinking about that damn bulb but my baby is complete again:)
