•• All Injectors on sale! (FAST, Siemens, DeatschWerks) •• HINSON Motorsports
All of our Fuel Injectors are on sale!
http://www.hinsonsupercars.com/Pics/...Comparison.jpg Most injectors will max out at 80% duty cycle and this is the accepted industry standard. After you install heads, cam, intake, your sucking in alot more air and your motor needs more fuel! Your injectors will be unpredictable when maxed out and you do not want to be running out of fuel at 6000+ rpm. If you have any questions about which injector size or accessories you may need, feel free to ask them in this thread. High Impedance FAST 33lb Injectors LS2 Part# 30332-8 DeatschWerks 35lb Injectors LS1 Part# 18U-01-0035-8 FAST 36lb Injectors LS1 Part# 303608 DeatschWerks 39lb Injectors LS1 Part# 18U-01-0039-8 FAST 39lb Injectors LS3/LS7 Part# 30397-8 Bosch 42lb Injectors LS1 Part# 0280155968 DeatschWerks 42lb Injectors LS1 Part# 18U-01-0042-8 DeatschWerks 42lb Injectors LS2 Part# 13U-00-0042-8 DeatschWerks 42lb Injectors LS3/LS7 Part# 16U-00-0042-8 FAST 46lb Injectors LS2 Part# 30462-8 DeatschWerks 50lb Injectors LS1 Part# 18U-01-0050-8 DeatschWerks 50lb Injectors LS2 Part# 17U-00-0050-8 DeatschWerks 50lb Injectors LS3/LS7 Part# 16U-00-0050-8 FAST 50lb Injectors LS3/LS7 Part# 30507-8 FAST 55lb Injectors LS1 Part# 305508 FAST 57lb Injectors LS2 Part# 30572-8 DeatschWerks 60lb Injectors LS1 Part# 18U-01-0060-8 DeatschWerks 60lb Injectors LS2 Part# 17U-00-0060-8 FAST 60lb Injectors LS1 Part# 306008 Siemens 60lb Injectors LS1 - EV1 Part# 107961 Siemens 60lb Injectors LS1 - EV6 Part# 108191 DeatschWerks 65lb Injectors LS3/LS7 Part# 16U-00-0065-8 FAST 65lb Injectors LS3/LS7 Part# 30657-8 DeatschWerks 72lb Injectors LS2 Part# 17U-00-0072-8 DeatschWerks 78lb Injectors LS1 Part# 18U-01-0078-8 Siemens 80lb Injectors LS1 - EV1 Part# 110324 Siemens 80lb Injectors LS1 - EV6 Part# 109991 FAST 85lb Injectors LS3/LS7 Part# 30857-8 DeatschWerks 88lb Injectors LS1 Part# 18U-01-0088-8 DeatschWerks 90lb LS3/LS7 Injectors Part# 16U-00-0090-8 DeatschWerks 95lb Injectors LS2 Part# 17U-00-0095-8 Low Impedance Lucas 120lb Injectors LS1 Bosch 160lb Injectors LS1 Fuel components you may need for your build Caspers Electronics Injector Adapter EV1 to EV6 Part# 109076 LS2/LS3/LS7 Car using an LS1 Injector Caspers Electronics Injector Adapter EV6 to EV1 Part# 109077 LS1 Car using an LS2/LS3/LS7 Injector FAST Injector Harness Adapters - EV1 to EV6 (8 Pack) LS2/LS3/LS7 Car using an LS1 Injector FAST Injector Harness Adapters - EV6 to EV1 (8 Pack) LS1 Car using an LS2/LS3/LS7 Injector FAST Fuel Injector Spacer Kit Makes an LS3/LS7 Injector have the same height as an LS2 Injector Katech Fuel Rail Spacer LS2 LS1 Injector in an LS2 Manifold and Fuel Rail |
probably stupid question.....but prices shown are for each and not a set correct?
Well this sux I just ordered yesterday some 83lb injectors. I would have rather ordered from you guys. bump for good sellers.
Originally Posted by AntonioZ06
(Post 1570880296)
Originally Posted by Z06wanted
(Post 1570881188)
Hey Brian... You think I could get a set mailed to Lanes shop?
Need some svo 42lb Let me know, Thanks D |
Originally Posted by 2klen4u
(Post 1571139749)
Need some svo 42lb Let me know, Thanks D 205-267-6387 |
The above ad says the LS7 style 65# injectors are rated at 58 psi. The link, for the 65#, says they are rated at 65 psi fuel pressure.
For LS7/L92/L76 Fuel Rail & Harness, Rated at 65 psi Fuel Pressure. |
Originally Posted by Bink
(Post 1572722817)
I'm confused. :confused::confused: |
(Post 1572722817)
I'm confused. :confused::confused: Seth |
Originally Posted by HinsonSuperCars
(Post 1572728431)
Sorry, that was an error on the description. They are rated at 58 psi fuel pressure.
Seth |
(Post 1570902018)
The prices shown are for a set of 8.
:thumbs: |
Originally Posted by deadcafe
(Post 1572793520)
Do you still carry the 42# svo's for the LS1?
Seth |
(Post 1572795227)
Yes we do.
Seth |
(Post 1572797187)
I am waiting to hear from the tuner as to whether I need to get them .
Thanks Seth |
PM sent
Just ordered SVO 43#'ers. Thanks Seth!
-Ty |
Originally Posted by Ty.
(Post 1573067738)
-Ty |
Need injectors for a boosted LS2, around the 700hp mark. Suggestions?
Originally Posted by RandomTask
(Post 1573477929)
Thanks Seth |
Are these prices still good?
