Converting C4 bilstein shocks to coilover?
Is this the kit that is being used to convert the stock C4 bilstein shocks to coilover?
I would imagine you need a slot machined in the shock to accept the lock ring? Who can do that? What size and length springs are used? Where would i get them?http://store.summitracing.com/egnsea...5&autoview=sku Thanks fellas!!:lurk: |
That is the kit I used on my C4. You can send them to bilstein and they will do it for you, or you can probably contact them and they can tell you how to machine the groove and could be done by a local machine shop.
Originally Posted by Vector Vette
(Post 1570311013)
(Post 1570311013)
I see on bilsteins site under services,they list a price of $10 each for putting the groves in.Not sure if that is rite or not. What springs did you use? What length and rate? Thanks again!!:cheers: |
I would call Randy at DRM if I were you. They have everything you will need.
Originally Posted by ghoffman
(Post 1570312679)
On this,im looking to see how its done. |
(Post 1570312679)
Again,looking to hear from guys that have done this on there own.I know there are kits out there.
Sleeve kit-$70 a piece Springs-hyperco,im assuming about a 10"-$60 a piece What i would really love to do is find a sleeve kit for my dbl adj qa1 shocks. Anyone make a sleeve kit for a qa1 shock? |
Found this place that makes sleeve kits for all kinds of shocks.
http://shop.a1racing.com/coiloverkits.aspx Including a kit for qa1 shocks. http://shop.a1racing.com/cok12413.aspx |
OK,sleeve kit doesnt work for the direct bolt-in qa1 dbl adj shocks.The main body is too thin to machine the groove for the c-clip lock in.
The bilstein sleeve kit will work but im looking for a dbl adj shock. Now looking into using a qa1 dbl adj coilover shock with a 2.5" hyperco spring and special mounts to bolt them to the car. I seen in a search that hardbar made some of these brackets. Anyone have any info on them or a qa1 coilover setup? Thanks!! |
Yes, Vansteel is now selling a new kit for C4's, and soon, a similar version for C5's and C6's. We (Hardbar) designed the upper clevis, and the lower rear C4 mount and did dyno development on the shocks. Best bang for the buck you can get either in a single or double adjustable. They are 100% each dyno tested, and are 100% made in USA and cost less than the competition.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1906 http://www.vansteel.com/_custom/part...00%20copy1.jpg |
(Post 1570319187)
No, I do not know the spring rates they are shipping them with, but they are genuine Hyperco springs and I am sure you can get any rate you wish. They are no where near a Penske, but the cost is not there either. They are a twin tube bypass shock with a gas separator bag. The knobs do work, but work best in the middle settings. When we dyno'ed them, there were some issues, but that is why you do testing. QA-1 was VERY receptive to suggestions and are dyno'ing each and every one in this program as a final QC check. They do have nice threaded aluminum bodies with Acme threads like a Penske, which is very nice for the spring hardware, and the upper clevis is virtually identical. The lower mount is included in the $1699 price for the singles, $2299 for doubles for C4's!
(Post 1570319418)
No, I do not know the spring rates they are shipping them with, but they are genuine Hyperco springs and I am sure you can get any rate you wish. They are no where near a Penske, but the cost is not there either. They are a twin tube bypass shock with a gas separator bag. The knobs do work, but work best in the middle settings. When we dyno'ed them, there were some issues, but that is why you do testing. QA-1 was VERY receptive to suggestions and are dyno'ing each and every one in this program as a final QC check. They do have nice threaded aluminum bodies with Acme threads like a Penske, which is very nice for the spring hardware, and the upper clevis is virtually identical. The lower mount is included in the $1699 price for the single for C4's!
Well, on full soft it is REALLY soft and then tapers off at the full hard position. The Penske is very linear with each incremental click being very close to the next or previous amount. The price points are in a different league though.
(Post 1570319551)
Exactly, but not everyone needs that either.
(Post 1570319749)
That is the intention of this kit. Springs are about $80 each, so you can do exactly that. Let's put it this way, the shock is alot better than any other non-high end (Penske, Moton, Ohlins, etc) adjustable shock I have seen.
(Post 1570319907)
And thanks for the information. I'm full of questions. :thumbs: |
