Throttle bypass tubing?
Hey everyone.
I was browsing mods for my C5 z06, and spotted the most simple of them. theres aparently a tube , which pushes coolant through the throttle body. when the car warms up, this in turn warms up the throttle body, heating the air passing through it. so theres a simply bit of tube connector, which alows you to bypass this. Was just wondering what your thoughts were on this, seemed like a simple idea to me, and something which could be DIY'd. but im unsure of the possatives against the negatives? Chevy put this water system in for a reason, butim unsure what it is?.. maybe to stop the throttle body freezing up or something? |
I just wanted to say "HI" before someone comes in and tells you how to search old threads.
:D |
I've never worked on that part of my car, so I'm not sure on the exact details, but on other cars (if it's what I'm thinking it is) was called a few different names, idle air control, cold start bypass. Basicly it uses coolant to determine the engine temp and during cold start up it bypasses a certain amout of air around the throttle body. When the car warms up the bypass closes off. In a nutshell, it is for cold startups.
Originally Posted by chevylad
(Post 1570217740)
Yup, a throttle body coolant bypass.
You can use a hose coupler. I think it's around 3/8" or so. You might have to extend the hose on the engine side to reach the hose from the rad. Or just do as suggested and get a new hose long enough to replace both.
(Post 1570217740)
I bypassed mine over the winter when I had the intake off. I now have a slight throttle tip-in hesitation/surging but I'm not convinced it's the bypass. I just haven't been able to pin the problem down yet. So, the bypass might be the problem or it might not, I just don't know. Peter |
you will gain ZERO by using the bypass
Originally Posted by SJPD
(Post 1570221262)
Peter |
It makes taking things apart in the future easier, but other than that, serves little performance purpose. In a cool climate after running the car for a few minutes, you MIGHT see a fractional HP increase, but definatly nothing you could feel....and it would be so inconsistant, that even an engine dyno would have a hard time picking it up.
