New window sills
Finally replaced outer sills on my 89' coupe. I experienced one minor delay. When you remove screws from the door make sure you remove the two screws under the door lock lever. I didn't see these initially and couldn't figure out why the door face wouldn't come off. Once these were removed it was an easy install. Ready for summer. :withstupid:
Did yours have 3 rivets to drill out?
And what strips did you use, OEM or aftermarket? |
:lurk:
