Originally Posted by mark@TGO
(Post 1570223553)
When a new trans is released we generally start hearing symptoms & failures within the first year or so. When it's a performance car we hear it even sooner. As soon as the car gets out of warranty the phone rings off the hook.
Mark |
Subscribed :cheers:
I get a flare up between 2nd and 3rd.
How do I fix this problem? |
A6 vs 4L60E Problems
Originally Posted by LS WON
(Post 1570223721)
Does it appear that the A-6 is going to have more problems than the A-4 4L60E transmission?
Most of the transmissions projects that we have done we almost always find more problems than the main complaint that owners & shops are seeing. Time will tell... Mark |
flare up
Originally Posted by Finelee
(Post 1570226640)
How do I fix this problem? You can contribute to the research of these complaints. Mark |
(Post 1570228561)
We will not know this until the project is complete.
6l80E
(Post 1570229163)
:thumbs:I would be interested in your final analysis:cheers:
:lol:
(Post 1570229732)
The final analysis will be in a TransGo box!!!
Welcome! You are a site for sore eyes on this site!
I used all TransGo parts back in my '87 GN days to rebuild all my trannies!:thumbs: |
I'm not sure if you guys read my post #48?
I would venture to say I currently have one of the highest milage A6's with 41,600 right now. I am a H/C/Bolt-on car around 460-480rwhp. I have no issues what so ever 95% of the time. Before I had Chuck COW (Corvettes of Westchester) tune the A6 TCM (there is no vacuum shift anymore, it's all electronic and it has it's own computer) I had 4-5 different issues. Now with his A6 TCM tune, the only issue, when cold and less than 5% of the time, it will flare a bit on the 1-2 shift when cold. It will do it once, that's it. I could'nt be more pleased with this trans. Let it warm up before you hammer it and you would be surprised how well they will perform. I do believe most of the issues in this trans are in the stock GM tune from the factory. IMHO. My A6 was crap before the tune. I would'nt even have kept the car if it was going to be that way (stock tune). Now when TransGo has 700rwhp version available, sign me up. |
tcm tunned
I had my 2007 A6 professionally tuned using HP tuning software. up and down shifts were adjusted along with pressures. i have had engine modifications including a comp cam. the trany now is completely different than stock and i do not see any shifting problems.
note: i do not hammer the throttle until i have oil temp up to 140 degrees which also gives the trany time to warm up. there are no delays in shifting in any of the gears. i can only hope this A6 stays this way. |
(Post 1570228561)
I've always LOVED TRANS GO Products.
Between my laptop and the TRANS GO techs, We're gonna be able to make beautiful music together! I'm in! Chuck CoW |
Mark,
A few of us are having the same problem with the Paddle shift not shifting under WOT. I have a 08 A6 Cont. with 5,000 miles and when I try to paddle shift at 5900-6000 rpm under WOT, it hits the rev. limiter and shifts after the rev's have dropped down. Trans works fine in auto and the paddle shift works okay under normal driving. Got any suggestions? Thanks, Dan Dement |
WOT shifts
Originally Posted by StoneOakDan
(Post 1570372217)
Mark,
A few of us are having the same problem with the Paddle shift not shifting under WOT. I have a 08 A6 Cont. with 5,000 miles and when I try to paddle shift at 5900-6000 rpm under WOT, it hits the rev. limiter and shifts after the rev's have dropped down. Trans works fine in auto and the paddle shift works okay under normal driving. Got any suggestions? Thanks, Dan Dement We do not have an answer for this complaint at this time. We have spent some time with the Valve body & circuit design. We have a approach that we are going to take to address some of these issues. No proven data or fixes just yet. Until it's fixed it's all just talk.. Thanks, Mark |
(Post 1570372217)
Mark,
WOT shifts
Originally Posted by adam205348
(Post 1570381925)
Is this only in 1st gear or this also happens in 2nd and 3rd? Have you tried to slowly bring the car up to 6000 and see if it will shift. I know there is a delay in the shift with the Factory tune and in 1st you almost have to press the up shift button at 5000 rpm to keep it from hitting the rev limiter because the car revs so quickly. In 2nd gear it is not AS bad but you still will have to shift 500 or so rpm before you actually want it to shift to have it shift at the actual rpm you want it to. The tune can be adjusted by Chuck or anyone else that knows what they are doing and able to make a ton better but it will never be INSTANTANEOUS.
It would be very difficult to make the shifts instantaneous with out tearing up the gear train of the trans. The transmission needs some type of regulation or accumulation during a gear change for durability. Regulation of any type creates some shift time lag. During my high school years when I first started working on automatics I thought I was so smart. My hot rods shifted with bang into gear so hard & they would always peel rubber. Eventually I got sick of replacing the trans every 3-6 months from internal destruction. The result of eliminating all regulation during the shift. Yeah, I was real smart....not. Mark |
(Post 1570382073)
Dan,
Shifts
(Post 1570382097)
LOL, I know exactly what you mean mark. I have rebuilt man turbo 350's and 400's and always with your shift kits installed to make it the most positive and agressive shifts possible. THANKS MARK.... jk
Our kits are engineered to provide max shift firmness with out sacrificing durability while providing greater longevity. We could make them shift a lot harder. The end result would be a trans with less durability & a product with diminished value. It's simply not in our blood to go that route. Mark |
Yeah I know Mark I was just messing with you. You products have always been great and I cannot wait to see what you guys come up with for the 6L80.
