TransGo 6L80E transmission research
Hello forum members!
My name is Mark, I am a R & D technician for TransGo in So El Monte CA. I'm sure that some of you are aware of our products. For those who are not, since 1959 we have been the pioneering leader in engineering & development of Automatic transmission Re Programming Kits. Our primary focus with any transmission is isolate & correct the causes of complaints & premature failure. At the current time we are looking into the problems that the 6L80E trans is having with 2nd gear. The 6L80E/A6 is the 6 speed auto in the 2006 & later Corvettes. I would also like to hear the drive ability concerns/complaints that you are having. Any data & info you can provide is of great benefit towards this research. We are searching for Corvette owners who would be willing to participate in our research program. There is no cost to you. For more information you can contact me at..xcamapuccinelli@yahoo.com I hope to hear from you soon, Mark PS I will be glad to provide technical assistance on your automatic transmissions. If you contact me @ this link please put a subject title related to your question or problem. I'm getting floods of emails & it will help me keep it organized. Also include your first name so that I may address you properly. I'm still figuring out all the ins & out of the forum. I want to respond to all your questions, If I do not respond to it send a reminder to my email. I would like all questions posted on the forum so that everyone is in the know. |
Mark,
I've always known TransGo to be a quality company. It's good to see you guys fixing some of the problems associated with these automatics. Welcome to the C6 Corvette forums! Rick |
Welcome to the Forums!!!
Phil |
Hi Rick & Phil,
Thank you for the kind welcome. I am here to answer your transmission technical questions. Mark |
What problems are the A6's having with 2nd gear?
Hi,
I have not heard the 6L80/90E referred to as the A6? You are referring to the 6 speed automatic correct? Please clarify. Thank you, mark |
Originally Posted by mark@TGO
(Post 1570142572)
Hi,
I have not heard the 6L80/90E referred to as the A6? You are referring to the 6 speed automatic correct? Please clarify. Thank you, mark Here's a link to acronyms commonly used on the Corvette Forum: http://forums.corvetteforum.com/1551484390-post2.html Welcome to the forum!:thumbs: I'm interested in what happens to 2nd gear also. Is it the clutches wearing out because the 1st-2nd shift is the only shift that isn't clutch to clutch? I have the stronger 6L90E with the wider gears for 2nd and am curious if they also increased the number of friction disc in the clutch drum.:cheers: |
(Post 1570142572)
Hi,
I have not heard the 6L80/90E referred to as the A6? You are referring to the 6 speed automatic correct? Please clarify. Thank you, mark If you need any info, I would be glad to help. I have an A6. Phil |
Mark, sent you an email.
Originally Posted by pmj341
(Post 1570141080)
Phil |
pm sent
Welcome!:thumbs::thumbs:
Originally Posted by glass slipper
(Post 1570142986)
Yes, A6 refers to the 6L80E in the Corvette.
Here's a link to acronyms commonly used on the Corvette Forum: http://forums.corvetteforum.com/1551484390-post2.html Welcome to the forum!:thumbs: I'm interested in what happens to 2nd gear also. Is it the clutches wearing out because the 1st-2nd shift is the only shift that isn't clutch to clutch? I have the stronger 6L90E with the wider gears for 2nd and am curious if they also increased the number of friction disc in the clutch drum.:cheers: Welcome to Corvette Forum Mark. And I am sending you an email. |
Forum response
To everyone,
The response to my initial post has been overwhelming wonderful. I want to thank all of you for your kind words & welcoming me. I will keep the forum posted on our progress on 2nd clutch failure in the 6L80 series trans. We need vehicles for research purposes. We have a 2 leads from forum members. Please do not hesitate to write if you have any questions. Thank you! Mark |
Originally Posted by adam205348
(Post 1570150842)
You have the 6L90E in your C6? I would really like to know how?
Welcome to Corvette Forum Mark. And I am sending you an email. thanks Phil:lol: |
(Post 1570150842)
Welcome aboard and glad to see someone working to better the A6. Any plans to do a heavy duty build? (650+ TQ output)? FWIW, I'm curious to hear about the "clutch failures" in 2nd on these trans. We've read about the seals that leak, causing a "flare" in 2nd and sometimes 3rd and 4th.
Originally Posted by Evilways
(Post 1570153725)
Time will tell, thank you, Mark |
contact info sent
:lurk:
