Flap Flap... Flap Flap Flap... DIY
Once and for all get rid of the cargo shade flapping on you. Here is what you do. First make couple of rubber band loops like this. As you see they are about 1/4 inch wide and 6-7 inches long. I used white one for illustration. Black is a better color. I also tied a tie wrap to the loop so it holds better under the speaker cover (explained later)
http://img.photobucket.com/albums/v1...p/DSC01912.jpg Then you will need couple of handles from old blinds. These are the Plexiglas type with a hook at the end. Cut both at the other end and duct tape them together. The final length is about the width of the roof. Better yet measure your cargo cover length, should it have shrunk over time, and match it. http://img.photobucket.com/albums/v1...p/DSC01913.jpg http://img.photobucket.com/albums/v1...p/DSC01914.jpg Insert the rod you made in the cargo cover. http://img.photobucket.com/albums/v1...p/DSC01915.jpg Here is where you tuck the rubber loop you made under speaker cover. It is between the hatch strut attachment and where speaker cover bends. There is a sweet spot with soft carpet area there. http://img.photobucket.com/albums/v1...p/DSC01916.jpg Needless to say, attach the rubber loops to the rod hook. http://img.photobucket.com/albums/v1...p/DSC01917.jpg This is how the final product looks like. Amazingly when the top is stored in the hatch, the rubber bands pull the shade passing the top and it does not get stuck between anymore. http://img.photobucket.com/albums/v1...p/DSC01911.jpg Then you go and get the free Grilled KFC for Lili the cat. :) http://img.photobucket.com/albums/v1...p/DSC01909.jpg |
Great solution. Your poor cat, though. Someone stole his little face.
Originally Posted by bimmerborn
(Post 1570015726)
Good idea.
you could have started a business. Instead you let us all know how. Thanks!
other fixes proposed on past threads but loop fasteners is a neat addition. I used a 1/4 inch steel rod and inserted it in the pocket at the bottom of the flap. heavy enough to stop the flapping but still allows the hatch to be raised, etc.
Great! Thanks. Now, if I can find some old blinds.
Originally Posted by glacierbay2
(Post 1570015752)
Originally Posted by simplyphp
(Post 1570015840)
I see you got those free coupons too.. photocopier is your friend :leaving:
Originally Posted by DOOKEY
(Post 1570015954)
Originally Posted by dpigguy
(Post 1570015998)
Originally Posted by lh4x4
(Post 1570016082)
One more thing folks: Make sure the rubber bands do not pull down too hard. Otherwise over time the ends of the bottom of the cargo shade stitching will come off. |
very good stuff there! :cheers:
(Post 1570015998)
Z// |
Good idea
I put a steel rod in mine. About 1/2" diameter.
Hobby shops are a good source for wooden and plexi dowels.
Home Depot gardening has barbed plant post for under $6.00. They come in different sizes and are plastic that can be cut to length.
I've got one of those plant poles (that you put in the garden) in the lower slot, still flaps a little (but not noticeable).
What would happen if you just sewed a small hook into the end of the flap and attached the rubber band to that?
I've seen some really weird things happen in accidents and don't want to have those rods where they might come loose and spear me. Not likely, but not impossible either. Someone posted about crimping split-shot sinkers onto a piece of fish line and pulling that through the "tunnel" on the bottom of the flap. I tried that and it helped only a little; I ended up with so much shot in the flap that it was resting on the trunk floor but still it would flap around somewhat. |
Originally Posted by Gearhead Jim
(Post 1570021630)
Neat solution! The only thing left is to get a fabric dye pen and paint that band black! :thumbs:
Originally Posted by WAwatchnut
(Post 1570042088)
(Post 1570043209)
I used white bands for taking pictures. Actual bands are black.
Great idea but where did you get the rubber bands that big? |
