Do they make 28 inch slicks for 17 inch rim?
The 26 inch ET Streets I have now just aren't holding in 2nd gear. I was hoping to go up to 27 or 28s on my 17 inch rims, is that possible? Can 16 inch rims fit on the Z51? I have a 2007 Z51 6 sp man ECS supercharger running 15psi, water/meth injection etc. I'm getting ok 60 fts like 1.68 but 2nd gear is just spinning right through....any advice?
Originally Posted by blackbird345
(Post 1569851672)
You might have to go drag radial to get the height you're looking for.
(Post 1569851672)
(Post 1569851672)
I'm running between 12-13 psi
(Post 1569857048)
I've never used M&H Tires but they list some 28" tall, x 17 tires:
http://www.mandhtires.com/store.php?...mode=cat_click Ever thought about running some QA1 drag shocks up front, they would help keep the nose up and keep traction. I never ran ET Streets below 14-15 cold, because if I had to run them at like 11 cold I felt that I had to work on other aspects of the car tractionwise. |
But those you listed from M&H are drag radials...maybe I'll just have to go with new shocks up front, how expensive are the QA1s?
