Cai
Can anyone explain why there is such a huge difference in cost between CAI manufacturers and their product. Additionally, even though they appear to be the same ie. BBK and K&N; is there something different between the way they are made, their efficiency, or the materials used. Thanks
Originally Posted by Speedvanish
(Post 1569436516)
Larger companies actually have an engineering / R&D department, and can back up claims with real numbers. Quality is usually better and they actually spend money on advertising. With all this said, they can justify charging more money for a better item than a piece of pipe and a chinese filter on EBAY, and some people will not mind spending more for quality. Additionally, even though they appear to be the same ie. BBK and K&N; is there something different between the way they are made, their efficiency, or the materials used. Thanks Absolutely. Do some homework and you'll find out the differences. |
The K&N FIPK filter, for example, has carbon fiber endcaps, but for the most part, plastic and aluminum component costs to the manufacturer/vendor will vary according to how many they buy from the fabrication/injection/blow molding house. And don't forget about the amortization of tooling costs which can be very high, depending on the process.
Expect to pay a minimum of $250 and as much as $500 for a decent-to-high-quality intake system. |
You get what you pay for. If you want performance, expect to pay $$$.
Originally Posted by black98c5
(Post 1569439126)
performance = dollars as stated you get what you pay for:cheers:
