Best way to keep your tires black....
Is tire black crap in a spray bottle the only way?
It seems to make the tires almost sticky on the sidewalls and only lasts whats seems like 2 days untill the dark nice black color is gone.:willy: |
I use "Son-of-a Gun" applied with a rag. There's no "cast-off" to get on your fenders, it lasts, and leaves no sticky residue to soil your clothes. I also use it on my Chevy pickup's black back bumper top, and it looks fresh for months in this climate. Try it, you'll like it!
Adam's VRT (vinyl, rubber, tire) works real well. :thumbs:
I use Forever Black. wipe it on and let it dry, no slick mess so no dirt will stick to it. Looks like a new tire after your done. It doesn't make the tire shine but makes it a deep black just like a brand new tire is.
Zaino fan here. Their tire dressing doesn't sling, and brings back a deep, black finish without that gaudy super-shine.
Originally Posted by Alaskanpilot
(Post 1569432854)
I just wash mine with dish washing liquid.
http://img.photobucket.com/albums/v76/Tom99/04wheel.jpg |
I like Adams VRT.
The key is deep cleaning them and keeping them cleaned regularly so your dressing will adhere and absorb properly. I prefer to use a water-based dressing for looks and longevity of the rubber.
Zaino Z16 and Adams VRT are my favorites. |
Originally Posted by dvilin
(Post 1569434142)
I like Adams VRT.
Browning - if the tyres are parked for extended periods the antiozonant and oils dry out, as a result, the tyre begins to crack and rot. After it works its way to the outside of the tyre and is exposed to the ozone in the air, it turns brown. The technical term for this effect is blooming.
Tyre Cleaners - For any type of protectant to work well on rubber first remove any brake dust, road tar, grease and grime, wax and dead rubber from the surface to properly clean it. A tyre cleaner needs to be strong enough to tackle a heavy build-up of tyre dressings and road grime, but not damage wheel coatings. It should clean the tyres down to the original rubber surface, this is especially important when you apply a new dressing, as dressings won't adhere to, or create the right shine on dirty rubber. This tyre cleaner is a strong concentrate; spray-and-rinse tyres, without scrubbing, if you are starting on an old, neglected surface, use a fairly stiff tyre brush for the first application and a spray & rinse at least 3-4 times a year - HiTemp Tyre Cleaner For more information see article “Tyre Cleaning & Care” in the Detailing School section of Detailing Bliss forum... |
Originally Posted by TOGWT
(Post 1569438797)
Tyre Cleaners - For any type of protectant to work well on rubber first remove any brake dust, road tar, grease and grime, wax and dead rubber from the surface to properly clean it. A tyre cleaner needs to be strong enough to tackle a heavy build-up of tyre dressings and road grime, but not damage wheel coatings. It should clean the tyres down to the original rubber surface, this is especially important when you apply a new dressing, as dressings won't adhere to, or create the right shine on dirty rubber. This tyre cleaner is a strong concentrate; spray-and-rinse tyres, without scrubbing, if you are starting on an old, neglected surface, use a fairly stiff tyre brush for the first application and a spray & rinse at least 3-4 times a year - HiTemp Tyre Cleaner For more information see article “Tyre Cleaning & Care” in the Detailing School section of Detailing Bliss forum... Not sure I'd trust an article about "tyre cleaning" if they can't even spell TIRE! :lol: |
Originally Posted by Z06RL
(Post 1569439358)
While we carry many tire gels, sprays, and liquids to use weekly to keep tires black. I have found one coat of Poorboys Trim Restorer actually seals tires for weeks and keeps them black and glossy.
http://www.autogeek.net/pbtr16.html |
Originally Posted by loflite
(Post 1569440176)
Tyre is the British way of spelling it.
1. Tire and rubber cleaner w/ tire brush.
2. Mothers FX Tire shine(black matte finish) |
(Post 1569440889)
Well, now, that doesn't make any sense at all considering we speak the same language. But then again, I just learned something new. :thumbs:
Tyres: [: Tyres or Tires- English and American English respectively] For more spelling errors see the 80+ in-depth detailing article on Detailing Bliss [Two great countries, separated only by a common language] |
(Post 1569432854)
http://i127.photobucket.com/albums/p.../IMG_1444a.jpg |
(Post 1569440889)
(Post 1569440176)
BTW....ZAINO Is my choice. |
