Mobil 1 vs Mobil 1 Extended Life
Whats the difference?
I just read a thread about Advanced Auto Parts having a deal for 5 qts Mobil 1 5-30 and the Mobil 1 filter for $29. Not bad. I called and they told me that's for either the regular or extended life oil. |
Extended Service has extra additives to extend the period between changes. You can read exactly how much on the Mobil 1 website.
At one point, the Extended Life was not yet certified for use in the Corvette.....is it now?
Yes, seems like quite a good oil, and it doesn't meet that GM spec for Corvettes. (from here: http://www.mobil.com/USA-English/Lub...erformance.asp)
"Mobil 1 Extended Performance Pdf Fully Synthetic Engine Oil Print View Product Description Features and Benefits Applications Specifications and Approvals Typical Properties Health and Safety Product Description Mobil 1 Extended Performance 5W-20, 5W-30,10W-30, and 15W-50 are advanced performance synthetic engine oils designed to provide protection and performance at extended oil change intervals of up to 15,000 miles or 1 year, whichever comes first. Mobil 1 Extended Performance features extra performance additive that helps to provide outstanding protection during today's longer oil change intervals. Features and Benefits Mobil 1 Extended Performance 5W-20, 5W-30, 10W-30 and 15W-50 are made with a proprietary blend of high performance synthetic basestocks fortified with an advanced additive system, designed especially to deliver performance and protection during longer service intervals. Mobil 1 Extended Performance oils are uniquely designed to provide outstanding levels of performance, cleaning power and engine protection, even during longer oil change intervals. Mobil 1 Extended Performance oils are available in a wide range of viscosities. The 5W-20 and 5W-30 viscosities are recommended viscosity grades for newer vehicles. The 10W-30 viscosity provides excellent all-season performance and protection. Mobil 1 Extended Performance 15W-50 is formulated to provide outstanding engine protection for high performance engines and for consumers who want a higher viscosity oil and higher anti-wear performance ( ZDDP) than typically required by modern vehicles. Features Advantages and Potential Benefits Fully synthetic formula with Advanced SuperSyn System Prevents deposits and sludge build-up to enable long engine life.Excellent overall lubrication and wear protection performance under all operating conditions. Extra levels of performance additives Provides outstanding engine protection at oil change intervals of up to 15,000 miles or 1 year, whichever comes first Outstanding thermal and oxidation stability Exceptional control of oil breakdown ; Helps maintain stable oil viscosity Provides exceptional engine protection Helps maintain long engine life and is compatible with engine seals. Excellent low temperature capabilities Quick cold weather starting for fast protection and extended engine life. Provides less stress on your starting system Applications Mobil 1 Extended Performance engine oils are recommended for all types of modern vehicles, including high-performance turbo-charged, supercharged gasoline multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks. * Mobil 1 Extended Performance oils provide guaranteed protection of critical engine parts for 15,000 miles or one year, whichever comes first. Excluded service includes: commercial and racing applications; frequent towing or hauling; extremely dusty or dirty conditions; or excessive idling. * If your vehicle is covered by a warranty, follow the vehicle's oil life sensor or the oil change interval recommended in your owner's manual. Proper maintenance practices, including frequently checking the oil level to ensure that the appropriate amount of oil is present, are required to ensure effective performance. * New Mobil 1 Extended Performance 5W-20 delivers the viscosity recommended for most Ford and Honda vehilces since model year 2001. It is also the viscosity recommended for many Chryslers, beginning with model year 2005. Back to Top Specifications and Approvals Mobil 1 Extended Performance meets or exceeds the following industry specifications: 5W-30 10W-30 15W-50 5W-20 ILSAC GF-4 GF-4 GF-4 API SM,SL,SJ,SH/CF SM,SL,SJ,SH/CF SM,SL,SJ,SH/CF SM,SL,SJ,SH/CF ACEA A1,B1,A5,B5 A1,B1,A5,B5 A1,B1" |
Mobil 1 Extended Performance oil does not meet the Corvette spec GM4718M per
http://www.mobiloil.com/USA-English/...nce_5W-30.aspx Don’t use it |
Originally Posted by VETTE IV
(Post 1569390814)
Righto. As already stated, stick with Mobil 1.
(Post 1569390814)
Good post. At first glance, I would have thought it would meet GM spec. :cheers:
And as of April first, with the Mobil One rebate certificate, 5 quarts will cost $16 at WalMart...leaves lots of money for any overpriced filter anyone would like!:thumbs:
Originally Posted by cclive
(Post 1569391307)
Got it. Buy the regular stuff for only $16 at Walmart. :cheers: |
Originally Posted by AORoads
(Post 1569390732)
Good to know.....Thanks :thumbs:
Strange though that GM's own CD that comes with the corvette owners manual shows a gold capped bottle of Mobil-1 sitting on top of the LS3 in the maintenance section of the video when talking about oil changes.
I don't think GM even knows or isn't going to officially say it is the better oil. If anything, they are not going to encourage people to try to go for 15k mile intervals, if I had to guess. |
(Post 1569390814)
Since mine isn't a DD, I end up changing at 1 year way before 5K, so it's not worth it for me.
Guys,
I have seen countless oil analysis on Mobil products. The current oil standard is SM. The introduction of the SM standard mandated a reduction in Zinc and Phosphorus in the oil to around 800 parts per million or so. The previous standard was SL, which capped Z and P at ~ 1000ppm. By the way, SL Mobil Synthetic did meet 4718M. Anyway, it is my opinion that Mobil 1 Extended Life is nothing more than the old SL formula with a new label. I base this on oil analysis from the previous "regular" Mobil 1 Supersyn and the "new" Extended Life stuff......the numbers are identical. Stuff like this happens all the time. Some of these (if not all) certifications cost money. Sometimes it's just cheaper not to get it, even if the oil meets and even exceeds the standard. Another good example is Mobil 1 Truck and SUV 5W-40. It is exactly the same as the Famous Delvac 1, 5W-40 Gas/Diesel engine oil. Yet, under the Delvac label, the oil costs some 15-20% more a quart. Anyway, my point is, the Extended Life stuff will meet and exceed 4718. I would use it without hesitation.....not for 15k miles though. Rick |
Originally Posted by USAF-Vette
(Post 1569744209)
Guys,
I've currently got the Mobil 1 Exteneded oil in my Vette. The last time I was due for a change, I couldn't find the regular Mobil 1 and went ahead and got the extended oil just to get the change done.
I'll change it out when the oil life monitor indicates it's time for it, and will look for the regular Mobil 1 for my next fill. |
(Post 1569744209)
Guys,
I have seen countless oil analysis on Mobil products. The current oil standard is SM. The introduction of the SM standard mandated a reduction in Zinc and Phosphorus in the oil to around 800 parts per million or so. The previous standard was SL, which capped Z and P at ~ 1000ppm. By the way, SL Mobil Synthetic did meet 4718M. Anyway, it is my opinion that Mobil 1 Extended Life is nothing more than the old SL formula with a new label. I base this on oil analysis from the previous "regular" Mobil 1 Supersyn and the "new" Extended Life stuff......the numbers are identical. Stuff like this happens all the time. Some of these (if not all) certifications cost money. Sometimes it's just cheaper not to get it, even if the oil meets and even exceeds the standard. Another good example is Mobil 1 Truck and SUV 5W-40. It is exactly the same as the Famous Delvac 1, 5W-40 Gas/Diesel engine oil. Yet, under the Delvac label, the oil costs some 15-20% more a quart. Anyway, my point is, the Extended Life stuff will meet and exceed 4718. I would use it without hesitation.....not for 15k miles though. Rick :iagree: |
