Originally Posted by TonyC
(Post 1569362861)
No, I dont mean the rubber exhaust hangers, I am referring to the joint between the back boxes and the "X" pipe. On my car to move the back box forward away from the cross member it was necessary to loosen the clamps on these joints. I have LG Headers and X pipe with race cats, maybe mine was getting hotter but the expansion for the back box to touch the bolt on the cross member was quite considerable.
All I know is it cured the problem I had :) |
***update***
I went under the car and found no problems. I sprayed some WD-40 on the flap mechanism. This made it a lot better. If it stays this way I guess I can deal with it....It's almost undetectable.
Ron **EDIT** As of today, 3/23 the noise is gone. Seems the WD-40 did the trick! |
TTT for my edited results/success...
Ron |
Good info. My '06 does the same thing, but only after I modded the mufflers. I will have to spray some lube on them I guess.
:cheers: RICH |
Originally Posted by RichieRichZ06
(Post 1569411414)
:cheers: RICH |
I've got a 150 mile '08 that I think is doing the same thing. It is almost a groaning or mooing sound at about 2700 RPM coming from the right rear. I'll try lubing the damper. Never thought about that. The car has been sitting for almost a year.
noise
i was under my car to remove my z06 setup and noticed that the muffler was hitting the stablizer bar on the outside bottom edge..it seems that the Z06 muffler is heavier than the stock system and pulls down on the rear rubber mounts.. check yours you dont have to lift the car to see it. i have a very small dent but enough to bump it on cornering while hitting an uneven surface.. not often but you can hear it...
Originally Posted by Dr.Ron
(Post 1569411161)
Ron |
Originally Posted by nutrientcobra
(Post 1569314131)
I have a Zo6 I just bought and notice this as well. I was thinking exaust again because I had a C6 that did this and it was one mounting bolt on the back. But now I am thinking I have a brake rattling. When I get the sound to happen, if I hold the break slightly and keep accelerating, it will quit. It is driving me nuts thoe!
More trouble shooting today with a 6 channel radio. Got excessive noise when attached to the subframe bolts in the rear and also left hand muffler hanger. More to follow........next week when I replace a few parts to try and narrow it down. :thumbs:
Mine does it too. 12k 2008. Usually around 3k RPM, goes away right below, and right after. As someone said before, tinny, "RICER" sound. Will try WD-40 on flaps.
So the sound came back... SOMEWHAT....Not everyday. It's too weird. It is absolutely a lot LESS though since I did the WD-40 though.
I don't see anything the mufflers could be touching, so I don't know what else it could be. It truely sounds like the right muffler from the driver's seat....a head scratcher for sure. Ron |
(Post 1569439045)
Originally Posted by Fast06Z06
(Post 1569443734)
it has to do with heat.
Anxiously awaiting any findings you come across. Ron |
(Post 1569445041)
I hear you, but it's NOT happened on days where I was driving for 40 minutes straight...:crazy:
No sounds from my 08Z.
But my 09Z made this resonance pulling right out of the dealership when new. I have a about 1000 miles and no change. Hot, cold, gear, MPH, NPP fuse in or out makes no difference. The resonance starts about 2600 RPM and stops about 3200 RPM. In my car the resonance seems to be coming somewhere between right below the drivers seat and the rear tires. A passenger in my car asked if I had a SC installed when they heard the sound ... :rofl: . |
Originally Posted by joe11204
(Post 1569447537)
Originally Posted by GasmanZ06
(Post 1569451533)
That sounds exactly what I am hearing in my '09 Z. Except, mine only does it when warmed up, not cold.
My digital camera is m.i.a. currently. If I get a chance over the next day or two, I'll try to take a few pics w/ my cell phone... Ron |
(Post 1569453825)
Sounds like we're developing the 1st 2009 Z06 T.S.B.!!!:smash:
My digital camera is m.i.a. currently. If I get a chance over the next day or two, I'll try to take a few pics w/ my cell phone... Ron thanks man. theres always camera phones if you have one haha :D:thumbs: |
Just got an 06 Z and have the same issue. It seems to be more apparent in 1st gear up to about 2700 rpm's. Let me know if any of you figure out the solution. It's an 06 Z with 21k miles.
