air conditioning problems
to all the a/c gurus....
when i push the a/c button the light flashes for 1 to 3 seconds than it shuts off. compressor never engages. what is happening? anyone? |
If you lived in the Northeast, I'd say it was on hiatus...:D (sorry, I had to...) Bump for ya! Best of luck w' your problem. :cheers:
Any codes on the DIC?
Maybe check for low freon level. |
Wow! I just answered this question on a thread just the other day. :lol:
Check fuse #24 to make sure its not blown. If its ok, then its probably your freon charge. Usually the blinking light is a sign that its low and it won't let the compressor run. |
Sound like you have low freon. If you dont have enough in the system the pressure switch will not activate the compressor.
Originally Posted by kevin40zx
(Post 1568786286)
Check your HVAC codes. Using the Fuel + options 4 times buttons you can read all the codes. Pay attention to the ones under the HVAC section. |
air con
no codes in hvac section.
only code is 10-pcm PO 645 can anyone tell me what this code is? i did not find it in my code thread list. thanks. |
not sure what that code is, but I had that same problem with my car. I just had to recharge it. just fixed it last week actually
I think that will happen if the fan (blower) is set to too slow. Have you tried increasing the fan's speed on the HVAC controls before pushing the AC button?
