RPI SALE! Mild2Wild Wireless Exhaust Controller & "NPP in a BOX" for non NPP Cars
We are running a special on our current stock of Mild2Wild Exhaust controllers and NPP in a Box for non-NPP Cars.
There are 2 different options available: 1. Mild2Wild - For Cars w/NPP exhaust or Z06/ZR1 cars 2. NPP in a Box- For non-NPP cars (not Z06/ZR1 cars) 1. If you have a Z06/ZR1 or NPP Equipped car you just need this small unit: Mild2Wild works with the All 2006 and up Z06's and all 2008/2009 C6's (with the NPP bi-mode exhaust option) and the new ZR1. New Product.. Exhaust On Demand Imagine having the ability to turn your exhaust from MILD (exhaust ports closed) to WILD (exhaust ports open) using you OEM Homelink (found on your visor) or via the supplied remote. Also works with the new B&B fusion exhaust. This revolutionary product lets you control your, 2006/2007/2008/2009 bi mode exhaust system on demand via a tiny wireless remote or the Homelink feature in your car . One of the coolest technologies is the “bi-mode” exhaust. Whisper quite up until 3500 RPM and then a wide open race car sound as the flaps located in the tips open. The problem is the inability to control this feature. Up until now, the owner’s only choice was to pull the fuse or to install wiring, drill a hole for a switch to turn the quiet mode off (and these sell for $85). After spending $75,000, the last thing you would want to do is start running wires and drilling holes. Introducing the first and only wireless remote designed to give you full control over the exhaust. This patent pending product requires no drilling or running wires through your car. It’s a simple 5 min simple plug and play installation that anyone can do. Once installed, you will have full control over the exhaust mode, via a simple ON/OFF remote wireless controller or your Homelink transmitter (simple programming required, instructions provided). Once the Homelink is programmed, you can just use that to work your exhaust. Actually, you will get two sleek ON/OFF wireless controls that can be mounted anywhere and will control the exhaust up to 50’ away. The “OFF” mode gives you that race car sound 100% of the time. The “ON” mode works as the stock setting and is quiet to preset OEM 3,500 RPM . The switch can be used anytime the car is running, allowing you to show your friends what a cool exhaust you have as you can use the remote and open and close the flaps on demand. How cool to stand behind your car and demonstrate the exhaust, using the remote. The system can be removed in seconds and you will never know it was there. You will receive the professionally engineered plug and play wireless receiver, two miniature remotes (battries included) and the necessary homelink programing instructions. Take full control of your NPP/Z06/ZR1 exhaust with the #1 selling MILD2WILD wireless exhaust controller. Developed over 2 years ago, it quickly became the must have modification for any bi-modal exhaust equipped car. It’s Jay Leno’s and Scott Dixon’s (Indy 500 Winner) choice for their cars and has even been certified and used in many Corvette dealerships. MILD2WILD installs in less than 3 minutes requires no cutting, splicing and is 100% reversible. The unit comes with two wireless micro FOBs that allow you to open the bi-mode exhaust at any time so you can enjoy that great sound anytime. You will be shocked at just how great your car will sound and with a press of the button it will set back to the OEM setting. MILD2WILD remembers the last setting (shut off car with flaps open, starts with flaps open / shut with flaps closed, starts with flaps closed) and it also has a ZERO battery drain install. Cars built after 10/06 do not have the homelink system and you will need to use the wireless FOBS provided to operate the system. http://www.rpidesigns.com/images/jayscott.jpg Price: $89.95 In stock here: http://www.rpidesigns.com/shop/item.asp?itemid=895 2. If you don't have a Z06/ZR1 or NPP equipped car and still want to control your exhaust all you need are the mufflers and this unit: Mild2Wild "NPP in a Box" Vacuum Control System If you have a 2005-2007 C6 or 2008 that didn't come with the NPP exhaust from the factory you can now have that same exhaust setup with "NPP in a Box". Simply purchase this vacuum control system, get NPP mufflers and you are ready to go! Go from Mild to Wild with the touch of a button. Choose Mild and your flaps will remain closed for a quiet ride. Choose Wild and open those flaps up! Let the world know your drive the best! Please select option below, either LS2 or LS3 and we'll provide the correct system for your car. This setup allows you to start the car in Mild or Wild mode. Comes with a 90 day warranty. http://www.rpidesigns.com/images/nppbox.jpg Price: $169.99 In stock here: http://www.rpidesigns.com/shop/item.asp?itemid=1465 :cheers: |
Sounds like a very good product but why only a 90 day warranty?
Originally Posted by Blue Demon
(Post 1568426063)
Sounds like a very good product...
:thumbs: |
:thumbs:
Originally Posted by danl72
(Post 1568446007)
:thumbs:
Originally Posted by SonOfDreams
(Post 1568509386)
Great deal on the original Mild2Wild and to pick up some of RPI's other great items at the same time :thumbs:
If you don't have it, get it. Best mod out there without question.:thumbs:
Where do you suggest I get the Mufflers?
Originally Posted by Red Rochester
(Post 1568572328)
:thumbs: |
Thanks for supporting Mild2Wild :thumbs:
Nice deal :cheers:
(Post 1568572328)
You can sometimes get them on the auction site or in the parts section on this site. If you get them, you'll love this product. |
Great stuff and great service!
Originally Posted by Craigster05
(Post 1571677332)
For the "NPP in a Box" ; you say « 2005-2007 C6 or 2008 » ; What is different with later years ? Is there a reason why the NPP in a Box is not recommmended for 2009 and up ?
I have a non-NPP GS 2011 with LS3 engine and I just got NPP mufflers from a Z06... |
Hi, don't bother answer my question. I found what I need with another vendor.
Originally Posted by rejdrouin
(Post 1588023125)
