LS7 454 Camshaft Help!
I purchased this camshaft from the original owner. He pull the cam and lifters out of the factory crate motor never fired from the late 80's.
I do not have a cam card. He tells me it was the L88 version. This motor has the Open Chamber 12.5 pistons. The old schoolers tell me that it should be the 180 cam not the 535. Who can help me figure out the correct information? Thanks, Willie496 |
As I remember it... the 5535 was the L88 Cam with about 560" lift, and the 180 was the later ZL1 (Aluminum Block) cam, with around .600" lift. Duration numbers and LSA changed too, and It ran better than the older L88 Cam. Can't you find any part #s on it? Either would be bettered by todays Cams; 40 years of development ya know...
:chevy |
9181
K396 Are the only numbers on the end |
The LS-7 and the ZL-1 used the same camshaft 3959180. All L-88s even the late open chambered head '69s used 3925535. From the Chevrolet Power Manual here are the LS-7 specs: Intake/Exhaust Lash 0.24"/0.26" Lift 0.560"/0.600" Dur 347/359 Overlap 135.
Originally Posted by Blue71vette
(Post 1568307623)
Larry, Thanks for the great add! There is now enough information to degree the cam.
Originally Posted by Willie496
(Post 1568286330)
9181
Thanks for all the help..
Anyone looking for a set of 8 standard bore 454 (LS7) O/C 12.5 GM pistons pins and locks included? Willie. |
