low rpm miss
need help, I have a miss in the idle to 2000rpm range, lots of backpressure from exhaust, and no warranity as this was voided when I shipped the car to Australia. vehicle has about 6500 miles, this is the first problem since converting to righthand drive.any
chance it is the cats? anyone ,please let me know what you can troble shoot for me kind regards to all and agreat holiday as well |
check the plugs and wires.
I had a cracked plug before, sounds similar |
anyone please help
test equiptment...it will tell you whats up
Doesn't look like there's a common problem here or someone would have posted by now. I doubt it's the cats. Plugs and wires as suggested would be a likely cause but with only 6500 miles, I would think someone would have had to do someting around there (colateral damage during the RH conversion?) and it might be visible. The thing is, there are so many things that can cause this stuff in electronics today that I think Patton has the best suggestion; get some diagnostics hooked up and see what they can tell you.
All fixed, spark plug wire was connected with the boot,but short inside by about aquarter inch. pushed back together and no more miss
Originally Posted by yolo300
(Post 1568239754)
Happy motoring! |
+1 for me :-)
Have fun!! |
Originally Posted by BubbaDuss
(Post 1568241719)
+1 for me :-)
Have fun!! |
