Where are the fuses for the bose amp in a c4
Can anyone tell me where the fuses are for the bose amps in a 1990?
There are some fuses behind the hush panel on the right side of the car as well as some relays.Thet are a pain in the a$$ to get to.Whats the problem with the stereo?Amp-amps dead,CDM dead?
amps suck, they are dead and than some
3 fuses for the radio system - a 10A radio fuse - 12V battery input to the receiver/amp, a 25A wpr fuse - power to the windshield wiper system and ignition input to the receiver/amp, and a third fuse, a 5A lcd fuse - supplies battery input to the head unit. all fuses are located in the fuse box on the RH side panel of the dash - hope this helps...
:cheers: |
Originally Posted by Corvette505
(Post 1567725991)
(Post 1567725991)
Originally Posted by Z51JEFF
(Post 1567734895)
It might be the CDM box for the receiver thats dead,these systems are junk,the amps will go out and the CDM box will go out,just a matter of time.Ive been working on my own cars for years and removing the CDM box was without a doubt the biggest pain in the a$$ job I have ever done.
In my 92, there is an auxilliary fuse box I found above the passenger's knees, sort of under the glove box. I think I was looking for the fuse to the alarm system, my kid found it so I don't know what else is in that fuse box.
There is also a relay for the amp. It is located under the dash, to the right of the steering column.
(Post 1567720133)
I'll bet the fuses were not the problem.....let us know........... ........been there done that................:yesnod: |
