1979 Corvette Fuse Box
Where is the fuse box located and is there a diagram for the fuses? Is there a guide to fixing the windows? They barely work. The door locks are sticking as well....help!:bs
2 Attachment(s)
Located on the firewall up above the driver side kick panel (below the dashunder the light switch).
Attachment 48162014 Attachment 48162015 If you're new to the C3 and the 79 you'll find a copy of the AIM (ie Assembly Instruction Manual) to be real useful. There is also a forum member offering pdf's of year specific wiring diagrams if you just send him an email. Helps alot. Don't remember his member ID so hopefully someone else can chime in. Best of luck |
Thank you so much for making my job easy!! I love forums !!! :cheers:
his name is papawana,
but he sent me a lot of stuff 79 specific. if you want any of it, pm me your email and ill send what ive got |
One of the best things you can do for working on the electrical system is get yourself one of those laminted posters of the wiring diagram. I belieive it's Lectric Limited where I got mine from. It's tacked on the garage wall right on front of where the Vette parks and I refer to it a lot.
wiring diagram
pm me your email address and I will send you everything I have for your '79
Originally Posted by spiritdancer18
(Post 1567335801)
I ran across this while searching for a retrofit blade type fuse center for my '78 other than those universal aftermarket types. Guess I never stuck my head under the dash of a '79, as I was not aware the blade type fuse panel had apparently become adopted as early as that year. My question is, has anyone retrofitted a '78 with this?
:cheers: edit - Anyone who wishes to reply to this post should PM me, as I've cancelled my "subscription" to it as of this edit. |
Originally Posted by TheSkunkWorks
(Post 1571983846)
:cheers: |
hey mate
dandaman69er@hotmail.com
hey mate just bought my 79 and still wounder about little things like the aerieal is it elctric and if so where the switch and and little things like that if u had like a owners manual or something like that that would solve all my little drams lol thanks mate wouldbe greatly apprectiated |
Old thread revival can someone email me this 79 stuff as well ?
Supertaco@gmail.com |
I just bought a 79, and can't figure out why the turn signal/high beam lever on the steering column wont work. Anyone have any idea??
1979 wiring
Hi do you have the wiring diagrem for 1979 I have problem with my gauges light and turn signal light not working can you help me. pleas my mail is mabonly@yahoo.com
wiring diagrams
Originally Posted by Mahboob
(Post 1579307371)
dropped a penny in the lighter unit n dome light went out which fuse is for the dome light
wiring diagrams
Originally Posted by zc31
(Post 1579456792)
http://i283.photobucket.com/albums/k...9fusebox-2.jpg |
I had to get to the fuse box on my '79 too. It's way up under there. I felt like a contortionist twisting around and laying with half my body hanging out the car just to get to it. I accidentally hit my face on the steering wheel twice just by turning my head. Then again, I'm just talented that way. :cool:
Good luck with the windows and door locks! :D |
Wiring
Thanks it was very help made my work very easy
:salute: |
I just bought a '79 Vette and have all sorts of small issues. While reading through the forum I see you have some items that could be of use for the '79. Any chance I could my hands on those resources as well? None of my flashers work (turn or hazard), when I press the brakes the marker lights get brighter, my dash lights worked for a short time now they don't, and the list goes on and on. In fact I opened the kick plate on the drivers side and saw red wires simply cut but have idea what they do to or what they are for! I've got a real project on my hands here.
Thank you in advance for any help I could get. VetteMayer |
my email address should anyone have ANY resources I could use for my '79 Vette is as follows: mayer2247@gmail.com
Once again, thank you to everyone in the forum! VetteMayer |
wiring diagrams
Originally Posted by VetteMayer
(Post 1583024099)
