Interior light won't turn off
The two overhead dome lights in the bottom of the rear view mirror won't turn off. I can't find anything in the manual about it. The car is off right now with the lights still on. I'm concerned it's gonna drain the battery. Any ideas?
Thanks Kevin |
You probably hit the dimming switch to the right of the steering wheel.
It also turns on the two rear view mirror lights I sometimes do the same thing when cleaning the interior. :cheers: |
Sorry, meant to say left side of the steering wheel. :D
As indicated above, you've pressed the dash dimmer switch.
2005 owner's manual, page 3-18. Courtesy Lamps When any door or the hatch/trunk lid is opened, the interior lamps will go on unless it is bright outside. You can also turn the courtesy lamps on and off by pressing the instrument panel brightness knob. |
Seems like this question gets asked as often as, "What's that little red light on my passenger side visor bracket?"
I tried messing with that knob but it made no difference. They're staying on no matter what. Is there a specific fuse I can pull?
Get inside... close both door (completely) and the rear hatch... press the knob one time and check lights by holding you hand under the mirror... if you pressed the knob with a door open the light will of course stay on... :thumbs:
Battery Run-Down Protection
This vehicle has a feature to help prevent the battery from being drained in case any of the following lamps are left on; the underhood lamp, if your vehicle has this feature, vanity mirror lamps, cargo lamps, reading lamps, console or glove box lamps. If any of these lamps are left on, they will automatically time-out after about 10 minutes. To reset it, all of the above lamps must be turned off or the ignition key on. |
Originally Posted by KevinZ51C6
(Post 1567193818)
http://forums.corvetteforum.com/show....php?t=2007835:thumbs: |
Thanks alot guys, they're finally off, I was about to pull the damn lights out with needlenose pliers:smash:
Thanks again Kevin |
Just for info: The on/off buttons on the mirror work backwards (to me); pushed in is off, popped out is on. :willy:
(Post 1567194188)
This has got to be the stupidest design for a switch that I've ever seen. Other than testing the interior lights after they should be off, there's no way of knowing if the switch is engaged or not.
With all the little improvements and refinements that have been made to the car since 2005, I would have thought this one annoying little button would have been history by now. For 2009, it's exactly the same. I think if someone offered an aftermarket replacement for the dimmer/interior light switch they'd sell out overnight. |
Originally Posted by JimTN
(Post 1567193728)
2005 owner's manual, page 3-18. |
Originally Posted by maxp
(Post 1567196476)
every new owner ask this question:D welcome to the club
Originally Posted by StanNH
(Post 1567196997)
At least the '09's has a much more solid click when you push it in so you know you're doing SOMETHING!
(Post 1567194188)
:leaving: |
Originally Posted by GotVett?
(Post 1567197353)
:iagree: When I bought mine and drove 4 1/2 hrs. back from Atlanta, I didn't notice mine were on untill the next day. Also couldn't figure it out until I too got forum help. Thankfully, it must take more than that to run down the battery.
Dimmer Switch
This happened on my 05. Push the dimmer switch to turn them off, push it again to turn them on. There is no LED feedback on the dimmer switch, so if the lights stay on, it got pushed. Of course, you need to be in the car with the doors closed.
