Originally Posted by z06z06z06z06
(Post 1568275465)
marina blue and all other ls2 lovers,
i'm as big as corvette fan as the rest of you, but why are you wastiing so much time arguing about 6, 7, or 11 horsepower? whether or not your ls2 makes 395, 400, or 411 horsepower the following family cars - a chrysler 300, dodge charger, and jeep cherokee (to name a few) make more (425). i would hate for you ls2 guys to run into a soccer mom at the grocery store or wherever and start bragging about your 411 horsepower only to be called out by the young lady with her family truckster . more and more women know the numbers. fact is chevy should have put the ls3 in the 2005 vette to begin with. it is what it is. :yesnod::yesnod::yesnod: |
Originally Posted by Marina Blue
(Post 1568285478)
delta in dyno data x 3;) Tough to come up with a decent comparison when there is a range of 25 horsepower between all that chassis dyno data. (say that fast three times:D)
Modified LS2s still contend with a greater drivetrain loss.:yesnod: |
Originally Posted by AirBusPilot
(Post 1568285495)
I believe the argument presented on why that won't work is based on an off hand quote in a magazine by someone at GM who stated something to the effect that there has been "continual development" of reduced drivetrain friction with the C6. This has been interpreted by some here to mean the LS3 drivetrain has less friction than the LS2 drivetrain and therefore comparing chassis dyno figures would be meaningless. Since no one has offered any proof of this, I don't believe it, and I'm not even sure the quote was in the context of what they are trying to say it is.
You seem to criticize individual details rather than looking at the evidence as a whole, which is what supports my case for a stronger than advertised LS2. The thing is, statements from GM personnel in a position to know the truth preceded evidence. I’m sure you will not be satisfied with anything I say short of producing a dyno sheet from GM so we’ll leave it at that. |
(Post 1568286170)
You’re wrong about the argument being based on that quote. That quote was in the latest edition of Corvette Quarterly magazine. My argument was developed in March http://forums.corvetteforum.com/c6-c...e-for-ls3.html and then added into this thread in September and the “quote” was just added in as support a few days ago.
(Post 1568286170)
You seem to criticize individual details rather than looking at the evidence as a whole, which is what supports my case for a stronger than advertised LS2. The thing is, statements from GM personnel in a position to know the truth preceded evidence. I’m sure you will not be satisfied with anything I say short of producing a dyno sheet from GM so we’ll leave it at that. For example: ...You claim the LS3 has less frictional losses thru the drivetrain because the LS3 peak hp is 100 hp rpm less than the LS2, and therefore the LS2 is getting rated artificially lower because it must struggle to make power 100 rpm higher. You then assigned a percentage loss which you derived from thin air. ...You also make a claim that some of the wheel options for the LS3 are lighter, and that explains some of the power difference between the two engines (despite any chassis dyno numbers to the contrary). Yes, I am critical of the individual details you proffer here, and with good reason as your "big picture" collapses when the details are put under any kind of scrutiny. Substituting opinion and disguising it as fact is basically what you have presented. No offense and nothing personal. If GM didn't test the LS2 under the new standard, then no one knows the answer. |
Percent
5 hp as a percent of 400 equals just a little over 1%. Not too sure I get this issue.:)
Originally Posted by gunnerrun
(Post 1568289214)
Originally Posted by jimmie jam
(Post 1568289830)
the issue here is obvious. i want to be "right" and you are "wrong" no matter how much data you have. :D
I could bury you in data and it wouldn't mean anything if the data isn't real or relevant. |
(Post 1568289064)
To say that your "evidence" is weak would acknowledge that you actually have any evidence, which by any engineering standard you clearly do not. You seem obsessed with an idea you have formed, and have grasped at any straw you can find to support your argument.
It is easy to find supporting evidence when beginning with facts about true LS2 power. As far as your criticism of my evidence is concerned, the content of your own allegations is lacking. Let's take a look at the two you mention here.
(Post 1568289064)
...You also make a claim that some of the wheel options for the LS3 are lighter, and that explains some of the power difference between the two engines (despite any chassis dyno numbers to the contrary). Once again you are making assumptions that you seem to be pulling out of thin air, just like you did when you stated I was basing my case for a more efficient LS3 drivetrain on a couple of sentences in a Corvette Quarterly magazine article. 2. As far as forged wheels are concerned, I said they were reportedly lighter in weight and listed links to posts from two forum members who weighed these wheels. Their findings were that they weighed less than the cast wheels. Two to four pounds of weight in the rear wheels would not make a great difference on a chassis dyno, but will contribute to the combined difference when included with the other factors I mentioned. You refer to chassis dyno numbers as evidence to the contrary. The difference between morning and afternoon air pressure in the tires can cause a change in chassis dyno readings. Why do you mention these numbers as support for your cause when they vary by 25 or more horsepower between different dynos? If rwhp numbers are so unreliable that a decent comparison between chassis dynos can't be made, how in the world can they be used to accurately determine the effect of a small difference in wheel weight?
(Post 1568289064)
If GM didn't test the LS2 under the new standard, then no one knows the answer. You mention "LS2 under the new standard." I only have one source that said they did such a rating, so I admit to not being 100% sure myself--maybe 95% considering the supporting evidence (Crush1's post; calculations in "The effect of horsepower and weight on quarter-mile trap speeds for C6 Corvettes"; all existing GM engines gaining power when re-rated under the new standard; analysis of GM's performance numbers). You failed to mention the "old standard", which LS2 certainly was tested at and truthfully revealed by more than one GM employee positioned to know. Of course you don't believe that either. You don't agree with much of anything I have presented here and have made your contentions known in a very negative fashion. Further discussion is pointless, especially when I have to correct continuing statements characterized by a lack of understanding. |
(Post 1568290293)
(Post 1568290697)
you've already made that point long ago. what else is new?
(Post 1568290876)
No need to take this personally, I'm not trying to hurt your feelings. However, this is an open forum and I'll post when I feel it appropriate.;)
(Post 1568293054)
why would you thing that i have taken anything that you said personally? :crazy: why would you think that you hurt my feelings?:crazy: just so you understand my position, this is an open forum and i'll post when i fell appripriate also. ;);) you didn't answer my question, what else is new? :lolg:
What's new? Not much, just sitting around waiting to be called out for a flight. What's new with you? |
The only numbers I pay any attention to are the ones at the end of the quarter mile. As for the old cars, I put close to 200K miles on a COPO 427 Chevelle. I've also had two L78 396 375 hp Chevelles with over 50K miles between them. Although I have little faith in the seat of the pants dyno, I would put our 2005 LS2 in between the L78 and L72 but awfully close to the 427. From the factory, these old cars came with #68 primary (very lean) and #76 secondary jets and retarded timing in the name of emissions standards. Add to that little F70-14 tires for traction and they went nowhere fast. Getting the jetting and ignition curve right, along with headers, made a HUGE difference. To start with the F70s were half decent traction. After tuning, they were useless and the car got the biggest available at the time. In the computer age, that is all looked after. You have to remember that those old engines were on the drawing boards around 1960 and were at Daytona in 1963. With 50 plus years of development since then, the cars should run better and they do. Still, a well prepared 425 hp 427 can run run 12.2s. Not too shabby. Anecdotal, yes and that's no worse that talking numbers when you can be at the track proving the numbers. There are some pretty good formulas for calculating hp based on et, mph and weight. Those are numbers you can take to the bank.
Originally Posted by Keith Tedford
(Post 1580979152)
Ibtl.....:)
I just spent X amount of time reading this thread. Knowledge gain is is equal to 0. I have realized that some people cant do math......lol
So all those together mean we dont have an answer to how much variation in HP there is, right? Since when does 396 at the wheels = 462 at the crank with 16.8% driveline loss? Oh yeah, when you multiply 396 by 1.168 instead of doing it correctly. No math wizard here but crank hp = 100% and the at the wheels is 100% less the 16.8%. |
Wow, bottom line is that I can now order that 409 billet aluminum badge for my LS2 that I've always wanted to!:thumbs::thumbs:
Originally Posted by TLS_Addict
(Post 1580980421)
Originally Posted by jschindler
(Post 1580980819)
No point in even going down that road. There is way too much information out there since this thread started in 2008.
LS2s have plenty of pep, if the 12s came with one that is what I would have. :thumbs: |
